Water pump keeps coming on (1 Viewer)
Bluemooner
1,722
8,069
Ribble Valley
Dreamseeker Fifth Wheel
4 years
My water pump keeps coming on so at a guess i must have a water leak somewhere its an Elddis Aspire where would the best place to look? The motorhome is under warranty but i would like to know the best place to look if it happens in France
Andy
lunarman
2,155
2,451
South Glos
since 1994
Are you losing water? If not sometimes the pressure switch on the pump leaks (pressure leak not water) and the pump will cycle for a couple of seconds to rebuild the pressure. Mine does it sometimes usually when a tap has not been used for some time, usually in the middle of the night.
Could also be a bit of dirt in the diaphram preventing a good pressure seal
John
sedge
Jul 7, 2009
5,502
13,081
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Err, excuse me for asking a seemingly completely daft Q - have you tried the switch first? - only that happened to us first time out in the van (we'd had it exactly 6 days) after crossing to France!
Turned out the baccy Pete had stashed in the locker at Adinkerke about an hour earlier had fallen over ! Of course he didn't think of checking that at first ........
:ROFLMAO: :Doh:
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
We had this problem earlier in the year whilst in Spain.
It turned out to be caused by a tiny leak in the water pump.
Brisey.
Bluemooner
Bluemooner
1,722
8,069
Ribble Valley
4 years
Thanks for your replys i cant find any water leak i am going home tomorrow so will have a proper look, Jenny which switch?
Andy
Terry
11,926
9,032
Lincolnshire
Can't remember ;)
Hi if you cannot find a small leak (wrap all jionts you can find with a bit of loo roll :winky:)then the seals in the pump are gone :whatthe: you need either new seals or a new pump --take it back for a new pump :thumb: don't let them change seals :Smile:
terry
Bluemooner
Bluemooner
1,722
8,069
Ribble Valley
4 years
Just been under the bed to have a good look though i had found a leak well it looked like a leak but no water strange i also managed to cut my head whilst trying to have a good look think i will have a shower and go to the pub
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
It only takes the tiniest leak to make the pump thro in, and often it can really take some finding. The loo paper already said is a good way if you can get to all the joints. The seal that goes between the two halves of the pump is a favourite, especially if you didnt drain it completely last winter. After a midnight flood from the toilet valve a couple of years back, we always turn the pump off at night now.
g8ysn
638
417
ng219ep
coachbuilt
g8ysn
had simler turned out to be leaking seal in tap in washroom, easy to fit like a figure three ooo,s:cry:
capinpugwash
511
629
Hampshire
Since 2005 (20 years Caravan before that)
Have a look at the little dump valve that dumps the water from the hot water storage cylinder to see if it is weeping. Check where it exits under your van.
This can cause a drop in pressure and make the pump cycle.
