Water pump activating at ramdom
Discussion in 'Tech/Mech General' started by stevec, Jul 15, 2014.
  1. stevec
    stevec Funster
    Sep 24, 2013
    647
    215
    Norwich
    We were away for our second weekend in our 2006 Autocruise Starfire. Everything ok except that once or twice the water pump started up on it's own and didn't stop until we turned on/off a tap. The pump sounded as if it had very little load on it....it was ticking away at a higher rate than normal. When we turn on a tap it ticks fast then gradually slows down when we turn off the tap as the pressure builds up. It almost sounds as if there is an air lock in the pump. But putting some water through the pump when the tap is on clears it. I can't see any leaks anywhere and the taps don't drip. any ideas?
  2. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    Don't know for certain about autocruise but some vans, eg my auto sleeper, have an adjustable pressure switch in the water line. If so it could be a simple adjustment.
