water protection valve
Discussion in 'Motorhome Chat' started by june123, Oct 16, 2012.
  1. june123
    june123 Read Only Funster
    Jul 12, 2012
    350
    134
    Staffs
    Looking for advice again.
    Weather being good after a first very frosty night we had a day out in our Burstner and were surprised when the toilet wouldn't flush. Then found taps wouldn't run. Then discovered water had been ejected outside the van.
    Got the manual out and discovered that at 6 degrees or less the water protection valve operates and empties all the waer from the hot and cold water tanks. I suppose this is quite a good thing to have but isn't 6 degrees a bit high? After all, living in Staffs 6 degrees is quite Springlike! Anything we can do to change this?
  2. hilldweller
    Dec 5, 2008
    27,576
    26,688
    Macclesfield
    You can AT GREAT RISK hold the red knob up with a clothes peg.
    But forget it's there and it could cost you BIG MONEY.
  3. andyman
    andyman Funster
    Sep 23, 2007
    1,156
    513
    Leicestershire
    I use a R clip as it is easier to fit than a clothes peg. I the winter we drain down every time we get home.
    Andy
  4. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi Leave the boiler on low that should do the trick has the water within will be hot. Pete :thumb:
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,758
    23,206
    Narrfoook
    I always clip mine up but leave a note on the dash to remind me to unclip it when we move off
