Water problems!
Discussion in 'Motorhome Chat' started by paulel, Sep 3, 2015.
  1. paulel
    paulel Read Only Funster
    May 8, 2015
    49
    35
    Brittany
    I turned the water on thinking there was water in the tank but it was empty, so of course, no water came out of the tap! I then filled the tank and tried again. Water came from the cold side but slower than usual, nothing from the hot side. I did discover water running from an overflow pipe when I turned the tap on. I don't know if it has anything to do with it but the gas ran out at the same time. Anyone any ideas?
  2. Speve
    Speve Funster
    Jul 29, 2013
    2,191
    1,885
    Salisbury
    Have you checked the boiler water dump valve as its automatic and may have turned on!
    • Like it Like it x 1
  3. paulel
    May 8, 2015
    49
    35
    Brittany
    Wow that was quick! The people I bought it from put a peg on the valve, it's still there.
  4. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,621
    2,191
    Rutland
    If it's a yellow pull up one remove the peg and flip it down flat ,then flip with water.
    When draining down you pull it up to empty the boiler and allow air in to assist with draining the system.
    Vlad
  5. paulel
    May 8, 2015
    49
    35
    Brittany
    It's a black unit with a red plunger on top that moves up and down, the peg keeps it in the up position. I haven't had a problem with it up to now.
  6. Vlad The Impaler
    Apr 22, 2012
    1,621
    2,191
    Rutland
    Sorry can't help but someone else will I'm sure,make and model may help .
    Vlad
  7. laurieash
    laurieash Funster
    Jan 29, 2014
    612
    360
    HALIFAX
    Yes it will be the hot water dump valve . If open water will come out under tne van. I foget to close mine all the time, after drain down.
  8. paulel
    May 8, 2015
    49
    35
    Brittany
    I thought it was that yesterday and tried lifting it up and down but it didn't make any difference
  9. laurieash
    laurieash Funster
    Jan 29, 2014
    612
    360
    HALIFAX
    Does the pump keep running
  10. Jimbohorlicks
    Jimbohorlicks Funster
    Sep 3, 2012
    825
    1,054
    Cheshire, Treacle Town
    The peg stops the valve from opening and dumping the water. Normally when the weather is cold the valve will open at around 8 deg C for a Hymer. The peg is used to stop the valve opening. It would seem you have another issue elsewhere with water dumping -maybe a split hose or a clamp has come loose-My hymer has jubilee clips all round at the joints that used to come loose at times. trace where the water is dumping from and work back to the taps-favourite in mine was under thesink
  11. paulel
    May 8, 2015
    49
    35
    Brittany
    Yes but it's making funny noises. It's a new Reich (I think that's the name) pump. Maybe I'll try putting the old Hymer pump back.
  12. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,511
    2,736
    Surrey
    Well that would suggest the pump is running dry, are you airlocked? Many way to clear and airlock, simplest is to open a mixer when halfway between hot and cold, but cover the tap with your hand to prevent water coming out of the tap.
  13. paulel
    May 8, 2015
    49
    35
    Brittany
    As far as I could tell late yesterday evening there is a t connection on the pipe coming from the tank with a pipe that goes through the floor and that's where the water is flowing out. I'll have to have a better look tomorrow.
  14. paulel
    May 8, 2015
    49
    35
    Brittany
    I wondered about an airlock as I run the tap for a while with no water in the tank.
