Water problem - Help please
Discussion in 'How To' started by artemis, Mar 20, 2012.
  1. artemis
    artemis
    Jan 14, 2011
    80
    30
    Shropshire
    Filled water tank for the first time this year.
    Can hear pump trying to work but nothing coming through the taps and water running out under the van. Drain valve is closed.
    Boiler is a Truma combi boiler
    Any advice? Had hoped to take van away for a few days tomorrow.
    Elizabeth
    :cry::cry::cry:
  2. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    Have you checked the small frost protection "dump" valve on the boiler is closed?
    If it opened during the cold weather the water will just be pumped out till you reset the valve.
    My Truma frost protection valve looks like this....
    [​IMG]
    The red button on the top resets the valve,and stops the water draining out when the pump runs.
    Callum
  3. rangitira
    rangitira Funster
    Jun 30, 2010
    6,481
    13,592
    Cornwall
    Just had that prob, asked on here , got the solution, warm the dump valve with a hairdryer, (make sure the little red(?) button is in the up position,) should stop the pump once you system is up to pressure, (as long as you have got rid of all the air in the system by opening all the taps, start nearest the pump and work to the furthest away):thumb:
    • Like it Like it x 1
  4. Gromett
    Gromett Funster
    Feb 27, 2011
    8,242
    15,343
    UK
    Sounds like truma protection auto dump valve is open..
  5. artemis
    artemis
    Jan 14, 2011
    80
    30
    Shropshire
    Water problem
    Thanks for the advice. My husband assures me the boiler dump valve is closed. We have not had this problem before but it is only our second year with this van.
    Perhaps the valve is not completely closed.
    We will try again tomorrow and hopefully succeed. Any more suggestions as to the cause would be welcome.
    Elizabeth
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,456
    7,553
    Nr Watton in Norfolk
    If it's not the dump valve then it's possible something has frozen and split while laid up during the winter. Brian
  7. lorger
    lorger Funster
    Jul 11, 2008
    6,403
    7,854
    Dumfries
    Do you have a drain valve somewhere we have one that drains the hot water tank and all pipes and sods law every time i fill up its in the open position and as soon as i open a tap it empties tank :Rofl1: always say i will remember that next time :Rofl1:
    Ours is a wee yellow valve under seat just pulls up and folds down like flap switch
  8. artemis
    artemis
    Jan 14, 2011
    80
    30
    Shropshire
    John says we have two drain valves, one for hot and one for cold, both have been closed. It is all very frustrating!!
    :Doh::Doh::Doh:
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    then i'll go with Brian...something froze and either split or pushed apart.
  10. artemis
    artemis
    Jan 14, 2011
    80
    30
    Shropshire
    Water problem solved
    Problem was that tank has different valves for travelling and camping. Pick up point for pump in freshwater tank above overflow outlet when in travel mode. The water was drained when it had its habitation service and valve left in travel mode. we had never used this mode. It means no water available when travelling for taps or toilet. Crazy!! Who would want to use this?
    Thanks for advice, we can now put everything back in the garage and go away.
    Elizabeth
    :RollEyes::RollEyes::RollEyes:
  11. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,940
    1,959
    Warwickshire
    This is a 'shot in the dark' but it might be to do with the weight capacity of the vehicle (Max Authorised Mass - MAM). A lot of Artos are plated at 3,500kg MAM and a full tank of water, plus all the other things we tend to travel with, might well put them over this limit. Perhaps the travelling mode valve is there to prevent filling the tank beyond a certain weight - remember water weighs 1 kg / litre so an extra 70 litres might tip the balance - so to speak. Obviously, this may not be relevant to you if yours is plated at a higher MAM than 3,500kg.
