Hello,
The water level indicator on my van is playing up !!! When I fill it, it gives an accurate reading - then 5 mins later, it shows "empty" regardless. The fresh water tank has five seperate cable attachments running up the side of the tank (I assume detecting each level, i.e. empty 25% 50% 75% full) - which then attach to a water level sensor box - which in turn goes to the lcd display. I have had to disabled the low water alarm as it's a right royal pain.
Any ideas where I start. I have put fresh tank water cleaner (non chlorine) in there to see if it cleans up the sensors inside the tank. I don't appear to have any access inside the tank so not sure how to check/clean it (if it is related). All cables look okay to the sensor box and to the lcd display.
Why are the little things so frustrating !!! :Angry:
