Water level indicator
Discussion in 'Tech/Mech General' started by EA7VPG, Jan 4, 2016.
  1. EA7VPG
    EA7VPG
    Jul 27, 2011
    47
    28
    Malaga, Spain
    Thought I would impart this experience. The water level indicator in my Elnagh Sleek is a very basic design with five self tapping screws screwed through the wall of the 100 litre plastic tank under one of the seats. Each screw has a wire attached which detects water by resistance across each screw immersed which in turn illuminates four LEDs on the panel. As the water level drops so the LED's go out. Our motorhoming is usually in warmer climes however we ventured north from the Costa Del Sol to a rather chilly Santiago del Compestela where it was down to 2 degrees C. This created the problem. The tank condensed on the outside even though it was inside the motorhome which created water droplets shorting out the water indicator screws giving erratic and incorrect water level indications. The problem was cured by a thorough drying and lagging the tank with baby nappies as a short term cure. I assume more modern motorhomes have lagged tanks.
    atb
    • Like it Like it x 1
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,266
    33,245
    Lancaster
    That's very helpful and sound advice. (y)
    Not sure about that however. A bit messy?? :(
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,238
    3,656
    walthamstow east london
    best system is waste tank slightly smaller than the water tank when the waste doesnt run away its time to drop and fill
