Water leak through Status aerial (1 Viewer)
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Tonight on site, went to hoist the TV aerial, a rare occurrence for us, and water came out from the inside the raising pole itself, I had tried the aerial in the vertical position, first time for ages, any clues anybody?.
scotjimland
2,324
10,061
A Woosh bang
IIRC there is a soft rubber seal on the base of the aerial .. needs removing and replacing ..
or if no seal, it needs resealing with a non setting mastic..
there is also a rubber gland seal.. it may be leaking there .. could try some silicone lubricant .. otherwise replace the seal.
does it look like this Broken Link Removed
Broken Link Removed
Sep 26, 2013
4,169
5,155
Market Rasen
Self Build
Since 2003
It could have come a bit loose so you could try and turn the nut on the inside to tighten it.
TheBig1
17,630
43,277
the gland that the pole passes through goes brittle and hard if left unused.
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
If you have had it vertical water could have got in through the seam around the side, if it has come on the inside of the pole.
The whole thing comes out from the top and can be reseated.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If you had the heating on it could just be condensation given that you said it came from inside the pole
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
There was too much came out got it to be condensation, I will have to get up there and check the seals when we get home, Thanks folks.
Techno
Jul 28, 2010
15,475
20,756
May 2010
So how has water got inside the pole? The roof grommet has nothing to do with that it only stops water coming in around the outside of the pole
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Good thinking!
