Water ingress (1 Viewer)
Oct 26, 2016
162
54
kent
Burstner Elegance 810G
since 2003
Hello all, We have a Burstner elegance 810G 2015 our problem is the last time we were away I went to the gas locker to open the gas valve and noticed a lot of water in the locker,I pored some water over the locker door to see if it was coming in that way but seems ok? the only thing I noticed was the propane gas cylinder was very wet due to condensation,has anyone else had this sort of problem and how can I solve it?.
help Joe
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
help Joe
Think you will find that the water is condensation.most gas bottles seem to susceptible to condensation due to the very nature of liquid turning to gas ...don't know the technical term for it.. However you should have an air hole or grid in the bottom of the locker to let escaped gas and condensation out.
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
As you evaporate the liquid to gas the bottle will get cold and you will get condensation, if the locker lined in plastic, if yes I wouldn't worry too much as it should be well vented as well.
Martin
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
You beat me to it, latent heat of vaporisation is what they are thinking of I believe.
Martin
J
Oct 26, 2016
162
54
kent
since 2003
Thank you all for your comments I will investigate further.
H
Hagstrom
"A lot of water"?
Hmm. I could see that condensation on the bottles whilst in-use could dribble down to the locker floor but surely only a tablespoonful or two?
I don't get any condensation from the bottles in the gas locker at all but maybe I don't use the van when conditions are optimum for producing it. On a skiing trip perhaps?
I would find myself checking the gas drop out vent to see if it was protected against spray thrown up from the front(?) wheels.
Teuchter
Nov 4, 2014
1,404
4,001
Lee on the Solent
Hymer Mercedes MLI 580
I have been caravanning for 32 years but in 2014 I have"gone over to the dark side"
If you found a lot of water in the locker then I would not think it was due to condensation on the gas bottle - depends how you define "a lot" I guess
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
My new van ALWAYS has water under the rubber mat in the garage, it is not condensation as it is heated but proper leaked water through the door seals, but I cannot see where it is coming in. If I wash it I get a load and I do not use a hose or pressure washer on the doors. It is all Glass fibre garage and fully insulated. I have to soak it up with a sponge, any ideas???
H
Hagstrom
GwayGway, I had a water ingress problem through the locker door seals and no matter how hard I tried, a water jet from a hose couldn't penetrate. Turned out to be coming from the van underside body seams in heavy rain and was cured by more underseal in the right place.
Lenny HB
53,420
149,939
On the coast in West Sussex
Hymer B678 DL
I had bit in my garage on the side that faces the weather when sitting on the drive. Only happened in very heavy downpours with exceptionally high winds. Local dealer replaced the seal, only happened once since in a torrential downpour with 60 mph wind.
MillieMoocher
1,118
10,638
West Yorkshire
Autosleeper Kingham
40 years under canvas: Motorhome 2016 To 2020
Interesting problem, I too "thought" I had a bad leak in the garage of Millie, including a load of water under the rubber matting. I was really cursing Hymer and their supposed build quality.
However, it turned out that the water was actually escaping from my water filling hose which I keep in the garage. What was happening was that after use, there was still water within the hose, and this was escaping while driving along and in effect flooding the garage.
I now blow through the hose after use, and my "leak" has disappeared completely.
Just a thought!
