water in window
Discussion in 'Tech/Mech General' started by PORKSTER, Feb 7, 2015.
  1. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    972
    959
    Sussex coast
    I have noticed some times I get a little misting on my hab door window. Its is a comedic door and the window is like a double glassed sealed unit that opens. Today I noticed about 10mm of water in bottom of this window havnt had chance to take a close inspection yet but I couldn't find anything broken cracked.
    My friend suggested that because that window is facing south and I had the silver blind up its got hot and cold too quick causing condensation.
    I will add some photos there not great but give you an idea.
    So good people do I have a major issue ? Any ideas suggestions welcomed as always thanks in advance
  2. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,881
    3,286
    Beds
    We have had similar - I think that there is a small crack near the stay and moisture gets in. It disappears without any intervention.
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,070
    6,070
    West Sussex
    The windows are acrylic which is micro porous to water, to see condensation in them is common as small amounts of water can permeate through the acrylic. You will find one or two small plugs in the window on as nice warm day take the plugs out to let them dry out.
    I've never seen that much in one before worth checking for a fine crack, may be just a build up over a few years.
    • Like Like x 1
  4. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,088
    2,930
    Kendal, Cumbria
    Start laughing at its jokes & it'll be much happier.
    Sorry :imoutahere:
  5. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    972
    959
    Sussex coast
    Ha ha bloody predictive sex I should read before hitting post button
    • Like Like x 2
  6. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    972
    959
    Sussex coast
    I didn't notice any plugs but there may be some holes where its fixed
  7. Mattyjwr
    Aug 18, 2013
    1,881
    3,286
    Beds
    I don't mind predictive sex .... ;)
  8. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Must confess, I've never heard of that ...
    I've read about acrylic paint being micro porous to water and causing damp problems when applied to outdoor wood, but not acrylic windows..
    I've done some Googling but can't find anything. Do you have any information or a link for this ?
    EDIT..
    I have now heard of it.. thanks.. :LOL:
  9. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    972
    959
    Sussex coast
  10. scotjimland
    Jul 25, 2007
    28,934
    25,602
    afraid the link is
    The page cannot be found..
    thanks, just did a a search on CC website ..which confirms
    Double-glazed windows occasionally mist up between the inner and outer skin. They are made from Acrylic Plastic which is an outstanding material but it is to some degree hydroscopic (porous). This means that under certain extreme conditions moisture will slowly permeate through the material. For this reason Acrylic caravan windows are not sealed units. This is so any moisture can escape from between the panes. Under most circumstances there will be no moisture between the panes, but it can occur if it is cool outside, the air inside is moist and the inside of the caravan becomes warm very quickly. In this case condensation can form between the panes, as the temperatures and humidity do not have the time to balance
    also found this
    -Acrylic is a Porous Material.
    At first thought many people don't consider acrylic to be a porous material because after all, containers that hold water are made of it, right? This is true, but although water does not visibly pass directly through acrylic, it is absorbed by it and slowly leaches out the other side.
    cheers
  11. SandT
    SandT Funster
    Oct 15, 2012
    127
    384
    Malta
    OK, I'll be the first..........
    A "tap" on the window should fix it. :roflmto:
    Terry
  12. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
    Whatever you do don't put your hand on the window, or you will feel the pane!:imoutahere:
    • Like Like x 1
  13. maz
    maz Funster
    Jan 26, 2011
    2,535
    2,173
    Out there somewhere
    A bit of misting between the panes that comes and goes is normal but IMO not that amount of water. I had that happen on my van's washroom window and it was due to the window delaminating. It was replaced under warranty. However my van's windows are of the frameless variety - don't know if that sort of delamination can occur with framed windows.
  14. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,829
    13,556
    Bolsover, Derbyshire
    I reckon it looks a bit worse than it might due to rounded shape, I haven't checked my own windows, but can recall, certainly when tugging that the windows had plugs in small holes, never did know why. I think I would drill a small hole on the outside to let the water out, try to size it to suit a grommet and plug when empty
    But also cant really see how it got in or what harm it will do other than leave a water mark when (if) it dries out, that will be a nearly impossible to get at
  15. PORKSTER
    PORKSTER Funster
    Sep 15, 2009
    972
    959
    Sussex coast
    This morning I removed the window and emptied as much water as possible. This a emptied out the top fixing holes I couldn't get rid of all of it though. I then put it on a warm radiator wrapped in a towel I read this was a good idea. But all it did was mist up evan more but I think it was getting drier possibly. As day light was coming to an end I refitted window making sure the seals where clean etc. Just have to see what next couple of days bring if the window is leaking I favour it being from top mounting holes. As I could not find any other problems and that was only place I could release the water.
    • Like Like x 1
  16. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    786
    642
    Wet and cold place outside of M25
    If you had two top Fixing holes, as well as setting by the radiator to vaporize the moisture I think I would have tried blowing through with the hoover using the hose on the exhaust end ie. blow hot air thro between the panes. Or Mrs's hairdryer. In through one hole and the other working as the moisture laden exhaust. Have to choke down the size of the hoover hose My big windows have the holes with the little bungs in them haven't noticed (looked) on the smaller windows.
    Just thoughts, never had to do it. Yet !
