WATER HOSE RECOMEND (1 Viewer)
dshague
996
302
VAN CONVERSION
20 years
just changed my van .the old one had a truma hose to fill water with .left it for the new owners .
Witch standard water hose do you recommend .are the flat or flexi ones any good ? ,,,food grade or not ? filler is the round type ..thank you david
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I have a couple of different lengths of garden hose. I can't believe that food grade is necessary if a small quantity of water is flushed through before use.
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
Been using green garden hose for 9 years have a couple of different lengths that'll join together if necessary.
Tried a nice expensive lay flat jobby a couple of years back didn't last 6 months.
Ended up in a nice green skip in Pickering. :)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Feb 16, 2013
19,699
51,880
uttoxeter
ambulance conversion
50 years
I use a Blue food grade hose.
Yeah I got one of these, took me quite a while to pluck up the courage to spend 12 quid on an hose but after two garden hoses that were forever kinking , I did it and now I don't regret it
StefAndDi
408
931
Near St. Austell, Cornwall
Ceased motorhoming 1/3/16
2010 to 2016
This subject was discussed at length on the Caravan Club forum four weeks ago.
Most contributors stated that they use ordinary garden hose.
However, one member stated that toxic chemicals are used in their manufacture and many manufacturers of garden hose warn on their packaging that the hose should not be used for drinking water.
The reason I chose to use Blue food grade hose is simple. Take a look at the hose used in the manufacture of your MH. Chances are that all fresh water pipes will be Blue. In fact, the only place you are likely to see 'ordinary' hose in a MH or caravan is the supply to the toilet flush.
Stef.
Minxy
32,623
66,459
E Yorks
Carthago Compactline
A good quality garden hose which won't kink is what we used and have done for many years, cut into a 1/3rd and 2/3rd lengths which can be joined if needed so it covers most eventualities.
I would be cautious of the 'expanding' snake hoses as the amount of water that flows through them is quite a bit less than a standard hose as the bore is smaller, same with the ones that look like a coiled spring and also some of the flat hoses too, this means that it can take quite a bit longer to fill up your water tank as we found out once on an aire where we had to pay for water by a set amount of time rather than volume ... it cost us twice as much as everyone else to fill a smaller tank as it was so slow.
Minxy
32,623
66,459
E Yorks
Stef.
IMV the garden hose warning about not using it for drinking water is to ensure that it is NOT used for a more 'permanent' fresh water supplies such as supplying a fresh water tap on a campsite/CL as the water remains in it all the time and therefore the toxins/chemicals from the pipe could leech out into the water.
The food grade (blue) hose is used in motorhomes because it is a permanent installation and the water will sit in it all the time (except when you drain down obviously!).
The only time I would bother to use a food grade hose was if I intend to connect up to a serviced pitch where the water turned is on continuously during your stay and therefore the fresh water is in the hose for a long period of time.
When you are just filling a tank for a few minutes where the water passes through very quickly, using a standard garden hose won't have any effect on the water at all as it doesn't 'sit' in it.
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
If all you are doing is filling the MH tank then any hose will do, simply run the water through for a few minutes prior to filling he tank. The food grade thing is all about perminant installations of potable water supplies, the time the water spends in a hose is minimal as it flows to the tanks, so contamination from the hose materials is not an issue.
Choose a hose that's easy to store and does not kink. A hose that 'fights back' is a nightmare.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Stef.
We have red ones too!
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
We are in the same position as you, we've just bought one of these...
15 mt hose on a reel for under ÂŁ20.
Minxy
32,623
66,459
E Yorks
Jim
Ringleader
Jul 19, 2007
36,323
130,296
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Always used to use regular garden hose, but I only use the blue food grade now after one particular garden hose imparted a rubber taint to our water that stayed in the tank till we sold the van. Never had a good cup of tea in that van again.
dshague
dshague
996
302
VAN CONVERSION
20 years
like it ..being from Yorkshire wanting to save a bob or two could buy this on a Wednesday and get 10% oap discount ....
Oct 7, 2013
5,891
36,871
South Wales
Swift Escape Compact
Since 1988
Stef.
The warning re "non food quality hose" reminds me of the warning that Cadbury's Fruit and Nut chocolate may contain nuts.
Overkill.
StefAndDi
408
931
2010 to 2016
My post was not a statement of fact. Simply quoting a comment made by another party.
musson
487
165
grantham
low profile
since Jan 2014
I use one of the expandable hoses and find it ok ,and it is easier to store than garden hose that i used to use.
43,301
49,289
Flat reel hose in the locker.
Standard green garden hose if filling at home.
Pamper your stomach, you'll always have problems.
treat it like yer grandma did years ago and you'll be fine.
