water hose fittings
Discussion in 'Continental Touring' started by Coolbeanz, Feb 27, 2014.
  1. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    Can anyone tell me what type of water hose fitting is most commonly used in Europe at aires and campsites? Will I need a variety of adaptors or is there a universal end? I don't fancy (Glynn :Rofl1:) filling up the Hymer with a small water container as it could take a long time :BigGrin:
  2. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Just take a whole pile. There is no standard. Even take weird ones you can't fathom. You can trust you will come across something and that weird shaped piece of plastic with the odd rubber grommit will suddenly make sense.
    • Like Like x 1
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,955
    17,634
    YO11 2BD
    take a good mix of adaptors.
    I believe the French commonly use the same as us, threaded tap, but the thread is larger than ours.
    Large and small threaded (hoselok do one with both sizes in one) and a push-on type with a wing nut type hose clip for unthreaded taps.(two sizes..18mm and 24mm)
    [​IMG]
    [​IMG]
    You can never have too many adaptors.
    • Like Like x 1
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    [​IMG]
    The grey/red is from carrefoure the red fits many bournes
  5. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    Crikeys, even filling up with water isn't simple. Where did you buy all those from? I take it you bought the grey/red one from a Carrefour supermarket in France?
  6. Techno
    Jul 28, 2010
    14,140
    15,091
    Any garden centre or b&q
  7. Techno
    Jul 28, 2010
    14,140
    15,091
    The majority of bournes have a large threaded tap like this but there are small ones too like at home and smaller still where the white adaptor will suit.
    [​IMG]
  8. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
  9. Techno
    Jul 28, 2010
    14,140
    15,091
    Personally I would not recommend one of those. The small bores make for a painfully slow delivery of water.
    I just use any pipe as I have a water filter for drinking water
  10. Sidney
    Sidney Funster
    Jan 27, 2013
    1,237
    805
    Stamford
    If you like a flat, easy to store hose that is food grade and doesn't have to be completely unrolled to be used that's not a bad product. But it looks like you need to connect another hose to the centre to get it in your tank...
    I got a two bob hose that I cut into two pieces, one short one long. Seems fine
  11. Techno
    Jul 28, 2010
    14,140
    15,091
    I recommend these for tank filling. It replaces your filler cap and there are two types, the white for tanks that have overflows and blue for those without
    [​IMG]
    • Like Like x 1
  12. Larby
    Larby Funster
    Jun 17, 2012
    1,721
    3,997
    North Essex
    Cheapo garden hose, bag of adaptors. We drink the French tap water but fill plastic containers for drinking. No need for food grade hose to wash with and no need to unroll and roll back a flat type of hose.
    ps. Mole grips may be useful in an emergency, many French cemeteries are on edge of village and will have stand-pipe but possibly without handle!:thumb:
  13. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,604
    2,585
    Tunbridge Wells
    B&Q do a small diameter hose real that works pretty well for us for less than a tenner. I think it is 15m long. We have a separate 10m length of hose as well and a connector like the one on the right of techno100's photo.
  14. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,851
    3,345
    Eastbourne East Sussex
    The screw on adaptor that is not so readily available is the 1" one, the largest, so if you see one buy it. Preferably 2 as it's very easy to leave them on the tap (I have several times)
    Only occasionally seen at garden centres. Used on a few French taps.
  15. Techno
    Jul 28, 2010
    14,140
    15,091
    • Like Like x 1
  16. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,833
    13,588
    Bolsover, Derbyshire
    don't knock the watering can, I find it a great tool, keeps Bevs water consumption in the shower a bit keener when I tell het she only has 10 litres!!
    top up twice a day with 10 litres x 2, that is a lot of water if you don't shower daily
  17. Techno
    Jul 28, 2010
    14,140
    15,091
    :thumb:
    No.1 tool in my old gas locker. Buy one that has the fill hole near the handle at the rear NOT near the front! otherwise it ends up all over your feet when tipped right up.
    [​IMG]
    [​IMG]
  18. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,151
    3,573
    walthamstow east london
    we bought a cassete flat hose from ebay put one end on the tap at home to test it but nobody told us you have to unroll it first cassette shattered so we cut the hose in half and just fold it up
    • Like Like x 1
  19. Coolbeanz
    Coolbeanz Funster
    Feb 26, 2013
    1,378
    1,944
    Capel St Mary
    • Like Like x 1
  20. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,014
    11,442
    E Yorks
    Regarding hoses, forget the 'flat' ones as they are either a single flattened type of hose which you have to unroll completely to use and are a pain in the a*se to get all the water out of and roll back up, or the ones that consist of several small bore pipes which you can use without unrolling but have a very, very slow flow rate so it take ages to fill a water tank.
    There are also the spring/coil type of hoses but these again have a small bore and also when at nearly full stretch can be very difficult to hold in place for a long time as they want to recoil.
    There are normal garden hoses, which is what we have, although we did get a good anti-kink one as this certainly makes it much easier to unroll and roll again, so well worth the little bit extra it costs for them, they also tend to be tougher too so will last longer.
    There's also the new 'expanding' hoses (they look really rude! :Blush:) and whist they initially seem a good alternative I don't think in practice they would last long, I know one make in particular had a problem with the tap attachment fracturing.
    We have gathered up quite a few bits and pieces over the years and find we have had to use them all at some point. We don't bother with food grade hose at all though even though we do drink the tank water, use it for brushing teeth etc, as the water isn't in the pipe long enough to become contaminated - all we do is give the hose a good blast through with water before using it for filling to 'eject' any stale water remaining in it from a previous fill up - we've never ever had any tummy upsets etc from doing this over 18 years!
    I took a photo a while back of my 'collection' of water bits and bobs and now carry:
    20ft hose (yellow one which we cut in half from it's original length of 40ft)
    2 x 5L rigid containers which being tall and narrow can easily be slotted in the wash room out of the way behind the toilet covered up to keep it 'clean' of course! (We can keep this full of water if needs be to us for hair washing, washing up etc as it adds to our 66L water tank capacity).
    15L (I think!) collapsible water container 'cube' - the best ones are those with a handle on the top and side as it makes it much easier when pouring the water into the tank.
    1 metre (approx) piece of clear pipe with push on tap connector, useful for when we're filling the water containers which won't fit under the tap
    1 funnel - the black one was my original which was just a standard car petrol funnel, but now I've got a 90 degree elbow pipe with a green 'oblong' funnel instead so can actually do the job single handedly as it stays put in the filler point (one of us used to have to hold the black funnel in place and usually got sloshed by the other!).
    The yellow hosepipe is coiled into the black bag, the clear pipe is coiled inside this then the elbow piece and funnel goes inside this, all nice and neat; the smaller bits go into a small bag.
    Various tap/hose connectors and a small strap with slide buckle which can be fastened to the tap to hold the button on.
