Water hose adapters required for Europe?
Discussion in 'Motorhome Chat' started by cmb, Jul 27, 2012.
  1. cmb
    cmb Read Only Funster
    Jun 18, 2012
    17
    Hertfordshire
    Along the same lines as the 'LPG gas adapters required for Europe?' thread....
    What kind of adapters do I need for my hose in order to fill up in Europe? We'll be taking in France, Belgium, Germany, Austria, Italy and Switzerland.
    Cheers!
  2. Gromett
    Gromett Funster
    Feb 27, 2011
    8,174
    14,988
    UK
    4 spare hoselock adapters.
    male to male adapter for doubling up
    big and small thread to male
    the rubber one with the built in jubilee clip.
    Take some spare threaded ones as I can guarantee you will leave one on a tap at some point....
    • Like it Like it x 1
  3. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Hi CMB
    What you require are
    One rubber type push on fit ...as some taps may have no thread old style tap
    3 internal threaded tap connectors....1/2"...3/4"...1".....One tap connector you will use most of the time, the other two now and again, same as the rubber connector now and again, but you will need them.
    Hose pipe connector or connectors to join on or two or three pieces of pipe together
    Hose pipe push connectors to fit on your hose pipe...buy as many as you require for the hose pipes you have.
    Hose pipe.....1/2" is good enough.....if you buy a larger size hose pipe make sure you the size of connections fit the hose pipe....NOT the hose pipe on a roll...wind in.. wind out... waste of money to be thrown away a few weeks later either split or too time consuming having to wind in & out when other people are waiting to use the borne
    These ebay numbers below are just to give you a idea of what you require...you may find them cheaper on ebay or your local B&Q...
    these two are the same it is just the price...rubber connections
    http://www.ebay.co.uk/itm/HOZELOCK-...andTools_SM&hash=item588e2e83c7#ht_1057wt_850
    http://www.ebay.co.uk/itm/GREENBLAD...andTools_SM&hash=item4ab5db7039#ht_3264wt_850
    http://www.ebay.co.uk/itm/Hozelock-...andTools_SM&hash=item2572a363a9#ht_500wt_1100
    http://www.ebay.co.uk/itm/HOZELOCK-...andTools_SM&hash=item589497c9b9#ht_500wt_1083
    http://www.ebay.co.uk/itm/THREADED-...ndTools_SM&hash=item27c8ceac33#ht_2959wt_1045
    http://www.ebay.co.uk/itm/HOZELOCK-...ndTools_SM&hash=item2a0f6a614e#ht_3331wt_1083
    http://www.ebay.co.uk/itm/SIX-HOSE-...andTools_SM&hash=item2c650a7c01#ht_2707wt_859
    http://www.ebay.co.uk/itm/5x-Hose-p...andTools_SM&hash=item1c2973892e#ht_2198wt_850
    http://www.ebay.co.uk/itm/Hozelock-...ndTools_SM&hash=item2562645087#ht_3486wt_1083
    All these are simple and light weight and take just a small amount of room
    Mel
  4. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    I agree with gromett......when other people are waiting to get on the borne you may feel rushed as they all queue up...100 miles down the road ....Whooops ....I forgot to unscrew my connection:Doh:....or you and the wife or you and one of your children...100 miles down the road...who removed the threaded connection ,,NOT ME I THOUGHT IT WAS YOU...Yes you can buy them over here at maybe 3 to 4 times the cost as in the UK:Doh::Doh:
  5. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,078
    1,232
    St Albans
    And for the few pence extra, only ever buy proper Hozelock fittings. :thumb:
  6. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,662
    14,454
    North Lincolnshire
    That's the route we took in June, hope you enjoy it as we did.
    We used a simple watering can to top up.
    Ok as long as you aint too far from the tap, but then you arent going to use a full tank each day?
  7. Gromett
    Gromett Funster
    Feb 27, 2011
    8,174
    14,988
    UK
    Absolutely. I have never found a cheap one that was any good.
    I actually moved over to brass fittings for the main ones...
  8. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    I agree SuperMike.... a lot better connections are Hozelock... ....there are some very cheap crap connections ...but there also a couple of good makes now like hozelock on the market well at least there are in France...but they are not cheap....
    Also for CMB....I use one of these 110 x 90deg plastic bend and a 10 lt water container...(but make sure it is a tight fit in your water inlet hole...if not use a watering can) ..this is to save moving off site if only a few litres of water is all that is required till you move the following morning
    http://www.ebay.co.uk/itm/110MM-ABO..._Plumbing_MJ&hash=item2573420757#ht_500wt_867
    http://www.ebay.co.uk/itm/Sealey-WC...nts_Fluids&hash=item5ae5abcd92#ht_1207wt_1083
    And one of these to empty your waste to save moving again
    TRUG RHINO FLEXI BUCKET ...14ltr
    http://www.ebay.co.uk/itm/YELLOW-GE...rage&var=&hash=item3cbedd86e4#ht_2040wt_850 [/SIZE]
  9. olley
    olley Funster
    Jul 29, 2007
    3,826
    2,381
    Ipswich
    The Range do some half decent packs of fittings in brass quite cheaply. I have been using the same layflat hose for about 4-5 years now and its still ok, takes up far less room than normal hose.
    Ian
  10. Gromett
    Gromett Funster
    Feb 27, 2011
    8,174
    14,988
    UK
    My layflat hose was bought in 2005 when I got my first motorhome. I have been using it as a fulltimer for over 3 years now and it is still as good as new :thumb:
    If you look after them they last ok.
  11. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
  12. Rayb182
    Rayb182 Funster Life Member
    Nov 13, 2009
    1,486
    1,617
    Great Bentley
    We got a 2 gallon watering can, we use about 2-4 gallons a day, saves faffing about get hose out.
  13. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    A site we were on near Agde only had the type of tap you had to hold down for the water to flow.
    A resourceful Class A owner was prepared with some strapping with a ratchet connector - now we are! It doesn't take long to get wrist ache whilst topping up the tank.
    Steve
  14. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,833
    8,963
    NW England
    We had a bit of fun with water pressure at Le Croisic at Easter. I try to avoid pay by the litre water bornes if I can, but on this occasion I had to relent and use the service post. I made the mistake of putting my money in before I'd connected the hose up. The resulting jet that came out of the post shot a good ten feet horizontally before hitting the next parking bay in a fountain of wasted water. Getting the hose fitted into that was pure comedy - useful lesson learned there.
