Water heater
Discussion in 'The Beginner' started by Fermenter, Oct 18, 2012.
  1. Fermenter
    Fermenter Read Only Funster
    Sep 6, 2012
    104
    15
    Preston
    Hi all just bought a Chausson Welcome 76 and wanted to know if I had to do anything with the Truma cowl on the side of the van when running on gas. The manual is less than helpful. Thanks Reg
  2. Pikeman
    Pikeman Funster
    Nov 6, 2011
    292
    323
    Worthing
    Yes, take it off. Otherwise it will not fire up! Oxygen starvation!
  3. Gooney
    Gooney Funster
    Jun 2, 2010
    4,777
    7,872
    Flintshire
    I think you will find if you don't take it off and the heating does fire up you will find the cover in the next field:Doh:
  4. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,143
    Welsh marches
    is it the round one?, as opposed to one that is oblnge shaped?
    If its the former then no as there is no cover, if its the latter then yes take the cover off
  5. Fermenter
    Sep 6, 2012
    104
    15
    Preston
    Thanks for your reply it is round not oblong and is on the drivers side of the van
  6. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,143
    Welsh marches
    one job saved:BigGrin:
    Shouldnt need to do anything - we have the same on our Welcome 85, only down side is dont be sitting next to it when it goes in to blast furnace mode - its a tad noisey and can singe hair!!
  7. Fermenter
    Sep 6, 2012
    104
    15
    Preston
    Lol ok thanks for the warning. How effective is yours on electric?
  8. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,143
    Welsh marches
    Water heating wise - takes about 15-30mins to heat up from cold to the 60deg temp
    space heating wise, on the lowest 'power' setting - pants springs to mind, but good for just keeping an ambient temperature ticking over, not too bad on the highest 'power' setting, but if it gets really cold - sub zero ish then gas or a mix of the two is called for...and then its shorts time
    BUT - as you have a excellent make of van (not biased in anyway:Laughing:)...once warmed through they keep the heat in quite well
  9. Fermenter
    Sep 6, 2012
    104
    15
    Preston
    That's really good to know thanks very much for the useful comments. I agree a good van with an excellent spec.
