Water heater
Discussion in 'Auto-Trail' started by irnbru, Mar 21, 2015.
  1. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,676
    10,556
    Glasgow
    We took off our flue cover to use our hot water. How do we turn our hot water off but keep the fire on without having to put the flue cover back on.?
  2. calion
    calion
    Sep 3, 2014
    430
    529
    Surely the flue covers need to be off if you're using the fire? Carbon monoxide etc!
  3. irnbru
    Jun 27, 2013
    5,676
    10,556
    Glasgow
    Our fire was on last night and our flue cover wasnt off.
    I think it only has to be off for the boiler to work.
  4. calion
    calion
    Sep 3, 2014
    430
    529
    When we had our caravan, we were told we must remove the flue covers when using the gas heater. I imagine it is to release any dangerous gases, perhaps motorhomes have a different set up. I'm sure someone will be along to clarify!
    • Like Like x 1
  5. davejen
    davejen Funster
    Aug 21, 2008
    1,248
    699
    Kirkpatrick Fleming Dumfries
    If you are using electric you don't need the fluecover off, only with gas do you need to remove it. Turn the switch off ours is in the bottom compartment of the cooker for the w.heater
    Cheers Dave
    • Like Like x 1
  6. irnbru
    Jun 27, 2013
    5,676
    10,556
    Glasgow
    We are wildcamping so using gas.
    Think ive solved it. Turned the dial above the door off. I thought that regulated the heat but it must be for just the boiler as the fire is still on :)
  7. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    It is only the Truma Ultrastore water heater that usually has a flue cover, the "fire" (which I'm guessing is a Truma 3002 series unit) is a completely separate entity and therefore the water heater and its controls/flue cover have absolutely no bearing on its functions.
    D.
    • Like Like x 3
  8. calion
    calion
    Sep 3, 2014
    430
    529
    Thanks Dave. I know we have to remove the vent covers when we run the fridge on gas too. I suppose there's no harm in me being over cautious where gas is concerned lol !
    • Like Like x 1
  9. hilldweller
    Dec 5, 2008
    26,900
    25,750
    Macclesfield
    You only get it wrong once.
    • Like Like x 2
  10. dave newell lvs
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    Your fridge will work perfectly well and safely with the winter covers in place if the temperature is low. They should be used in temperatures below about 8* C.
    D.
    • Like Like x 2
