- Aug 18, 2014
- 23,539
- 131,300
- Transit PVC
- 16 years since restarting
Well the Truma stopped working a while ago. Eventually had a look at the pcb & found something that had obviously been badly soldered from the outset & had damaged the board so linked out with a small wire. replaced turned on S/valve clunks piezo goes ,then nothing . Doesn't light ?
Fiddled for a while & as occasionally there was a damp patch I stripped the lot out. Found burner blocked solid with dust/earth ? If I didn't have a witness, my nephew, I would seriously believe that it hadn't worked before & I was dreaming it.
Anyway silver soldered inlet & outlet pipes. cleaned burner , assembled on its own & connected to temp. gas supply , turned on switch & volia , perfect .
If I tried it once ,I tried it dozens of times. Then reassembled it all & refitted all to van. Left Water fill up & gas bottle until today . Done that this a.m. & turned on & ..........nothing . Tried everything & this is exactly what it did the first time & never worked for weeks & then suddenly would open S/valve & attempt to light . Anyone any ideas ? I¡ve trawled the internet but cannot find anything relating to mine as it is a BO 10litre . B103 , gas only model & is obviously a very early model.
