Water heater on or off
Discussion in 'Motorhome Chat' started by errpaul, Sep 7, 2013.
  1. errpaul
    errpaul Funster
    Feb 27, 2009
    500
    57
    Wiltshire
    So we're currently away on our second trip in this new (to us) van. The water heater is gas only and wondered what people usually do......leave on whilst on site or only switch on when you need it?
    Had electric heater before so when on ehu always left it on for convenience in the past.
    What's best?
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,828
    13,503
    Bolsover, Derbyshire
    I find gas water heating so efficient I would turn it off till needed to save gas, but would no doubt forget to turn off, like you did we normally leave electric on all the time.
    When off sites I try to turn off water heater when not in use as I am always worried about running out of gas. I have no idea how much gas is used on 'tick over'
    David
  3. Melchior
    Melchior Read Only Funster
    Jun 26, 2013
    137
    80
    Amstelveen, Netherlands
    Our heater is a Truma (No idea what model, sorry) and it heats its tank pretty quick (and bloody hot!).
    Only use it in winter and my technique is:
    Wake up bleary eyed. If able, clamber over Miss M and fall down ladder. Regain conciousness, flip water heater on. Boil kettle, make tea for both. Miss M drinks tea, has hot shower. I have slightly cooler shower (I suppose the Truma tank isn't so large).
    what I'm trying to say is: It doesn't take long to heat it up so there's no or not much point leaving it on if you aren't using it.
    • Like Like x 4
  4. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,369
    2,277
    East Wittering. West Sussex.
    As and when required. The water stays warm for quite a while so it helps to conserve gas.
    Our opinion, others may differ. :thumb:
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,938
    We normally leave it off as it wastes gas otherwise. The exception is in cold conditions when we may leave it on low overnight to stop the automatic drop valve opening.
  6. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,550
    7,831
    Turn on and off as required, it doesn't take long to heat up.
    As above, in morning turn it on followed by the kettle.:thumb:
    Most of these water heaters are only 10 ltrs so once used you need time for it tomre-heat.. Gas is quicker than electric...
