water gauge fault
Discussion in 'Motorhome Chat' started by oozzie, Mar 2, 2015.
  1. oozzie
    oozzie Funster
    Aug 8, 2013
    68
    24
    CHESTER
    Hi, having problems with the water level gauge on the 2004 hymer. The flashing warning signal is on regardless of how much water is in the fresh tank. I have tried giving the probes in the tank a clean but no change.
    Now the strange bit. When first shown how to drain down the system, i was told to disconnect the pump to stop it running and i think it stopped the flashing. I have now disconnected the pump and the connector from the probe/sensor on the fresh tank and it is still flashing.
    Can anyone help, its got me confused.
    Thanks. oozzie
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,006
    13,842
    Bolsover, Derbyshire
    I have no idea on the technical fault, but would expect the gauge to indicate low if the probe is disconnected
    we have a Hymer as well and the gauge is not a lot of use really, rarely ever shows 100% even when spilling out of filler, then seems to sit at 75 or 50% until flashing 'nearly empty'
    when you find out how to disconnect let me know I will do the same to mine :D
  3. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,929
    3,395
    Eastbourne East Sussex
    None of these gauges is particularly accurate, but yours sounds as if the sensor is disconnected, even before you disconnected it. Perhaps a loose connection somewhere, hopefully not the dreaded wiring eating mice.
