Water filler cap. Will not lock. (1 Viewer)
Jaygee32
145
14
Norfolk
since 1976
Can anyone tell us how to get the barrel from the centre of the lock?
Key will turn but it doesn't lock. Have tried WD40 to free it but to no avail.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If memeory serves its a well documented problem, me seems to think the lock is not removeable as its a factory push and click assembly
A new one is the cure:cry:
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Agree with Geo on this but found with one soaking in warn water worked, you have nothing to lose.
Dave .:thumb::thumb:
JayDee
1,057
169
N. Devon
7 Years after 5 years with caravan.
If its one like this
Link Removed
you can buy the cap without a lock (I know Chelston sell them) and then you cut the old cap in half and remove your lock. Then you carefully tap the lock into the new cap, making sure the cutouts are aligned. Cap now works and with your original keys.:thumb:
John
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I assumed the lock is knackered and he wants to replace the barrel with a new one, or maybe I'm reading it wrong.
Jim
Ringleader
Jul 19, 2007
36,400
130,741
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Brand new ones don't work!, or didn't when I bought one new in 2006. It used to be a common topic on forums, I thought maybe they had fixed the problem. Some people lock them easy, others struggle, maybe there is a knack, or maybe you need to be a magician:Smile:
GJH
29,450
38,827
None, now sold
2006 to 2022
Is it, perhaps, the case that the cap isn't properly in position before the key is used? I've seen some people insert the cap and then try to lock it without first twisting it into position.
The cap has to be twisted clockwise a small way before the key is used to lock it. It should then move freely in either direction without coming out. To remove, it should be unlocked and then be twisted anti-clockwise before being pulled out.
Oct 14, 2007
3,985
6,244
Rochester
Auto-Trail Mohawk
16 fun filled years
Yep, chuck it in a jug of very hot water, that normally sorts em out.:thumb:
J
Jaygee32
145
14
Norfolk
since 1976
water filler cap
Thanks for all your replies. Will give the suggestions a go and let you know. It was a new cap last year. We'd had the same problem with the previous one!
Joan
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Had the same problem a couple of weeks ago.sprayed some silicon lubricant in but it didnt work straight away.gave it a good tapping. now it seems ok.:thumb:
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
about 2 years ago I had one that would not lock, also the hand grip would turn without any stop, I found that the inner part of the plastic assembly had come unglued from the outer cover, a few drops of super glue fixed it.
Doug...
haganap
12,758
26,445
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
always wonder'd why we even bother with locking water caps. Not like some-one is going to syphon your water :RollEyes:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi JG32
I Have never had much luck with that type of cap, the one on at present does'nt lock but stays in place, I did at one time for the Bessaccar buy a fiamma cap and conecting unit that one had lugs like on a petrol cap and I did find that ok, I am sorry now it went with the van on changing. Pete :thumb:
Douglas
2,835
400
South Wales,
True,but they might put something extra in as a sick joke!!
Doug...
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
oil and WD40 are not the best way to free up a jambed lock, regular use of graphite dust is the answer. Buy it from most motor factors.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I have had several they all seem to work when they want to the hot water trick seems to fix them for a little while but a new one will fail also:Doh:
Cupcake
114
14
Norfolk Broads
since July 2009
We've had the same problem but after reading this thread chucked it in hot water for a few minutes and hey presto it locked!
Thanks for the tip:thumb:
