My Motorhome dosnt seem to have a fresh water drain? I have found the dump valve for the truma heater it is the newer type with manually operated twist top switch and botton on the back ,and emptied all the water in the truma by maunually opening the valve(this was before this cold spell),and I left it open but couldnt find a fresh water drain?The fresh water tank is on the inside under front dining table main seat.The gray water valve is a pull handel just under the bottom of the van bellow water tank fill up valve and the actual wast tank is strapped to the unside middle of the van. I drained all the water by turning the pump on and as the truma dump valve was open it just carried on pumping the water out of the drain pipe behind the back wheel,ive opened the lid of the tank and it is completly empty . Any other ideas where a fresh water drain would be as ive searched high and low?? Ive also read all the books and nothing is mentioned ,it dosnt have a manual as such but indervidual books for each item fitted to the van . The Van is Mclouise Tandy 673G on a fiat 2.3.
Also ? If I turn of the 12V system by turning the masterswitch of nothing then works as their is no power from the batteries! But if I then plug the mains extension in everything works ie: 12V as well as the 240 sockets etc the control panel lights up and the 240 mains connection indercator glows.. I have found a charger under the drivers seat,that powers up automatically when mains is connected,my question is will this power up and run the 12V as well as charging when conected to the mains?? Thanks in advance Alan
