Water drain pipes and taps freezing up (1 Viewer)
Jul 10, 2014
179
57
Cheltenham
Elddis Encore 255
3 years
I took the precaution of having tank heaters and insulation installed when purchasing our vehicle. Subsequently I insulated the drinking water tank drain pipe which was surprisingly omitted. During the recent cold spell we had temps down to -6 on our last two nights. On the last night both drinking water and grey water drain pipes froze. As we were going back into storage I had to drain both tanks and spent time underneath with a hair dryer so we could get on our way. I now realise I need to insulate the 28 mm pipe from the grey water tank. However, I cant think of any way to insulate the small plastic drain down taps. has anyone any ideas please? I realise that those nights were the coldest of the year and it's not an every day problem!
Badknee
7,407
412,653
notloB
Vantage Neo
Living the dream.
Happy new year to you. There have been a few posts on here and the sensibly ones :) Recommend opening the grey water drain tap and run into a bucket/ container and it doesn't matter if it freezes and use bottled water if there is a chance of a deep freeze draining tanks before the problem occurs.
Badknee
7,407
412,653
notloB
Vantage Neo
Living the dream.
Pappajohn is right though anything to stop the cold getting to the pipe will help. We use heat trace wire on our static to keep pipes under the van from freezing.
Badknee
7,407
412,653
notloB
Vantage Neo
Living the dream.
Just open the taps and let it run out as you are driving along........
Wait for it.............
Cheers, Dave(y)
Bloody hell, so soon???
TIN HATS, GET YOUR TIN HATS HERE!! :xrofl:
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
Cheers, Dave(y)
That seems a jolly idea.....never occurred to me....probably best just to open the valve all the time.....except when on my drive at home.
Andy
627
689
East Sussex
A class Hymer
newbie
Oh you tease, you............:whistle:
musson
487
165
grantham
low profile
since Jan 2014
Try the silver bubble wrap insulation I think you can by it for wrapping pipes from wicks, if not cut the large sheet into lengths to suit
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Don't need to, just get a bucket with a large hole in it, and drain into it on site before you leave.
Just Joking!!!!!!!!!!
