Watch out for what an inverter can do (1 Viewer)
Jul 12, 2013
3,849
5,225
The City of Henlow
Adria Supreme
Since 1980
In Spain this summer, we bought an 800w inverter, not the most expensive pure sine wave type (whatever they are) to charge the batteries on our electric bikes; perfect!
As there was plenty of power available, I could not resist charging my little electric toothbrush. Big mistake! Apparently the shape of the sine wave does matter, well it did to my toothbrush, it destroyed it. ( later I read in the small print that this could happen)
Alan
JockandRita
11,402
148,457
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
I cant understand that.
Genuine pure sinewave is as close as it gets to mains leccy....and you use that at home without problems.
John, Alan is saying that it wasn't the most expensive pure sine wave type.
When I charge my Braun electric shaver via a modified sine wave inverter, the charge never lasts as long as a mains charge, but other than that, it seems to work okay.
Cheers,
Jock. :)
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Modified or Quasi-sine wave inverters: i.e. not pure sine wave models, can cause havoc with inductive motors and devices. As you have found out, electric toothbrushes are charged by inductive coupling and don't like square waves. This also applies to other devices that have 'contactless' charging. I have also read that quasi-sine wave inverters can destroy expensive hair tongs (e.g. GHD).
Derbyshire wanderer
1,269
2,366
Derbyshire
C class
15 years
Alan
I suspect that the inverter is NOT as described. Pure sine wave is exactly the same as mains power. Cooking the toothbrush can only point to it being modified not pure.
JockandRita
11,402
148,457
Lincs/Cambs border
N+B Flair 8000i
Feb 24, 2013
12,991
101,162
Bolsover, Derbyshire
Hymer S800
not long enough
Ah yes I see now (red wine must have muddied the thought from vision process).
I thought it meant a cheaper pure sine wave. Doh
So did I, Jock must be on Alans wave length
(did you see what I did there) :):)
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Alan
Anything very small is in danger from the rough treatment handed out by big cheap inverters. Their tiny capacitors and suppressors can't absorb the spikes created by the crude waveform.
300W pure sine way here.
Dec 12, 2010
5,367
21,180
Cumbria
since 2011
We used to have a teacher we called Sine Wave, he had one leg a bit shorter than the other and couldn't draw a straight line across the blackboard.
Feb 5, 2014
1,674
3,909
mid-Norfolk
since 2006
Do you remember those experiments at school where you (or teacher :sleep:) moved a magnet in a coil of wire, magically producing electricity? (It went under the heading of "electro-magnetic induction" - work it out!)
The faster you changed the magnetic field, the bigger the voltage produced.
This lesson will probably have led to a discussion of the transformer, where a changing voltage (in the primary coil) creates a changing magnetic field which creates a changing voltage (in the secondary coil).
The inverter provides electrical power to the "charging base": it produces a changing magnetic field which links to the device: a coil inside the device produces the electricity to charge (or fry) the internal battery.
When sinusoidal changing fields are applied, you get sinusoidal voltage changes. However, if you use a wave which suddenly change the field (eg triangular-shaped, or even worse, square shaped) then you get a sudden, large change in voltage (in the secondary).
This is what fries your toothbrush/hair-tongs or, as stated earlier, any "charged by induction" device.
SIMPLES :whistle: - Gordon
rosalan
Jul 12, 2013
3,849
5,225
The City of Henlow
Adria Supreme
Since 1980
Thank you Gordan, most enlightening for those who know about things like that. I think I too may have been a bit enlightened but Sangria does it better.
Alan
