Waste Water Sender Unit
Discussion in 'Tech/Mech General' started by Geoff Wilson, Jun 24, 2015.
  1. Geoff Wilson
    Geoff Wilson
    May 10, 2015
    10
    Chesterfield, Derbyshire
    Where can I get a new sender unit to show the water level in the waste tank on my 2004 auto trail cheyenne?
  2. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,461
    7,281
    Derby
    You don't need one..............just leave the drain tap open.............:whistle:
    serious replies may follow.............
    (y)
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,221
    7,339
    Nr Watton in Norfolk
    Really not worth replacing .... they are all notoriously unreliable as they get gunged up!
    • Like Like x 1
  4. scotjimland
    Jul 25, 2007
    28,934
    25,590
    have you inspected it.. do you know what type it is.. ? It may just need cleaning
    the most common type is just three different length stainless steel probes suspended in the tank, they work by conducting a small electric current through the water..
    as said, they can get gunged up, remove and clean is generally all they need..
    as for reliability.. must depends on what you put down the sink waste.. oil and grease float and eventually coat the probes, effectively insulating them..
    • Like Like x 3
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,977
    2,806
    Kendal, Cumbria
    If yours is the same as most others it will consist of a 5 metal rods. A cable (often ribbon cable) with 5 wires connects the metal rods back to the gauge. Other than the cable being damaged or the rods being covered in gunge there's nothing to go wrong.
    Edit: Too slow again.
    • Like Like x 1
