waste water pie (Elbow)
Discussion in 'Tech/Mech General' started by BgClick, Mar 11, 2014.
  1. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    Hi,
    I need to replace a waste water system elbow fitting, see picture, for our Hymer B544.
    Can anyone tell me what size it is and if its a general plumbing item or a specialist Motor-home item?
  2. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,819
    3,121
    Manchester
    Take the old one to a plumbers/diy place and see if they can match it.
    • Like it Like it x 2
  3. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    Hard to tell from a picture with no sizes but it looks a bit like overflow pipe size
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    Measure the diameter to find the size.
    Probably 20mm, 23.5mm, 28.5mm or 40mm.
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,780
    10,197
    an excellent place to find obscure sized plastic fittings is an aquarium shop. far cheaper than a motorhome accessory shop and in most cases better quality.
    for instance I replaced a load of convoluted waste pipe that kept blocking with reinforced smooth bore pvc pipe. half the cost and never had another issue with it blocking again
  6. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    Well B&Q didn't carry any :-(
    Its the waste pipe from the bathroom to the grey tank
  7. GJH
    Aug 20, 2007
    27,349
    34,968
    This is a 45 degree angle rather than 90 degree but it gives the inside diameter as 28mm.
    There's a 90 degree one here but maybe a shop local to you will have one in stock for comparison.
  8. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    The pipe is 28mm on closer inspection and a more scientific measuring process
    • Like it Like it x 1
  9. Plumberman
    Plumberman Read Only Funster
    Sep 29, 2013
    66
    40
    West Midlands.
    Hi BgClick,
    Try a dedicated Plumbers merchant rather than a b&q,
    They should be able to size the fitting and offer you an alternative such as a mechanical fitting which will tighten onto your pipe with a compression type fitting which will suit a variety of sizes.
    Hope this helps.:thumb:
    Your fitting is a 90 degree elbow.
  10. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    Probably a good idea I can get them online buy it works out to a tenner with postage so might as well get a pressure side push fit from a local shop
  11. Plumberman
    Sep 29, 2013
    66
    40
    West Midlands.
    Notice you are in West Midlands ,anywhere near Wolverhampton ? I carry a lot of
    Fittings and if you are local could probably help,:Smile:
  12. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    I am in Walsall :)
    If you have the time to spare I could come to you maybe?
  13. Plumberman
    Sep 29, 2013
    66
    40
    West Midlands.
    Let me know when you are available. I'm sure I could sort something.
    Look forward to meeting you,:thumb:
  14. Plumberman
    Sep 29, 2013
    66
    40
    West Midlands.
    Will give you ring tommorrow:BigGrin:
  15. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    Thanks for the call, its really great to know there are people about who want to help.
