waste water outlet (1 Viewer)
paul18
171
34
Somerset
C class
newbie, but was caravanner for 20 years
Another dumb question from me i am afraid! Is there some accessory available that fits over the external drain tap so you can use a hose to a drain hole on site?
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Depends what size outlet pipe, but whatever siZe you should be able to get relevant waste pipe connections/ reducer from any good DIY store / Screwfix / Toolstation. (y)
paul18
paul18
171
34
Somerset
C class
Looks like about 1.5 inches with an external thread
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
40mm ID
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Of course you can make something up-but on sites that cater for motorhomes the general idea is that you drive over the dump point and open valve. (y)
Techno
Jul 28, 2010
15,475
20,756
May 2010
Like the caravan club NOT
Techno
Jul 28, 2010
15,475
20,756
May 2010
Even on upgraded sites rather than put a gully across the road they added another grate & lid instead. Yet still it is often difficult to get over the grate and often there is only one and on the wrong side meaning you have to go the wrong way on a one way system.
Grate lids are often not put back properly (leaving the handle stuck up) creating a trip hazard and just the fact that elderly users have to bend down and lift one off is bad enough!
DanielFord
3,020
3,086
We use a washing machine waste hose, purchased from Homebase, the rubber bit fits perfectly over the grey waste tap.
Cal54
3,804
61,977
Southport, UK
Leisuredrive Renoir
Since 1996
Whilst having a pop at the CC does anyone else have problems with the height of the automatic barriers? I find that they are too low given that the drivers window doesn't go all the way down. I always have to undo my seatbelt and almost get out of my seat to get to the damn things.
Badknee
7,407
412,402
notloB
Vantage Neo
Living the dream.
Tuggers tugs are lower than us in MoHo's perhaps?
Badknee
7,407
412,402
notloB
Vantage Neo
Living the dream.
40mm? My grey water waste pipe is about 15mm, takes ages to drain.
That's why I leave it open all the time (y) :LOL:
paul18
paul18
171
34
Somerset
C class
I`ve been to garden centres, aquarists, B&Q and Wickes, cannot find anything that will fit. My waste pipe appears to be 55mm external width with a external thread. Anyone please got any ideas?
Lenny HB
53,395
149,802
On the coast in West Sussex
Hymer B678 DL
You can get 50mm dia pond filter pipe, would this push inside you end fitting? Available on eBay or any or garden centres with a pond dept.
3,097
97,670
Shropshire
Carthago chic e-line
Since 2013
Looking at your picture I would say it's a GF plastics valve,
time to look for a serious plumbers merchant or may be agricultural related. Looks as if someone kept the other part!
paul18
paul18
171
34
Somerset
C class
Thanks for that rb62, it makes sense. When I viewed the MH, that piece wasnt there, because I didnt see anything red (I think) so maybe it was fitted after the sale. It looks like its just been push fitted into the original tube, so I suppose it would pull out. Is there something I could purchase instead?
3,097
97,670
Shropshire
Since 2013
I should think the cheapest option would be to find something that will fit inside and then connect waste hose to that.Then you can still use the valve.
