Waste Water Outlet Valve
Discussion in 'Motorhome Chat' started by StitchUp, Apr 1, 2012.
  1. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Bridgend, South Wales
    And another question!!!!
    I've been working through our van correcting all those niggling problems, mostly electrical - lights etc.
    Today, I climbed beneath our Burstner to investigate where the wiring for the number plate light had disappeared to :Eek!:. In fact, there were no bulbs or holders either! I have new replacements.
    Anyway, I guess I located the waste water outlet valve.
    [​IMG]
    It's not exactly easily accessible!
    Is this the norm or do most vans locate the valve on the outside of the van? I'm sure I could easily fit an extension tube.
    Just interested to hear from others.
    I'm off to the van with my soldering iron to fit new connectors, light fittings and bulbs :Laughing: Loving pottering.
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    personally id extend it to somewhere more accessible and put the tap on the end with a small elbow so if you have to use one of those waste water containers you can.
    my waste drain tap is inside a locker on the side of the van being a double floor and has a bayonet fitting under the side to connect a hose to if i cant get over a manhole or have to use the silly black jerry can thing.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,892
    17,556
    YO11 2BD
    looks, from the pic. like the tap is part of the tank adaptor and cant be moved.
    simply buy a new valve and a length of convoluted hose and position the valve/tap where you want it then leave the existing valve open all the time.
    also wondering how it past previous MOT's with no number plate lights
  4. gordoncbrown
    gordoncbrown Funster
    Oct 2, 2011
    834
    568
    Scotland
    Ours used to be piped to a flexible hose that clipped up under the van behind the rear left wheel. I have now hard piped it, flexi connection from tank to first bit of pipe. I have lagged it as well. The valve is easily accessible and easy to turn so now Mrs Brown directs me over the drain point and opens it.:Smile::Smile::Smile::Smile::Smile:
    Gordon
  5. pappajohn
    Aug 26, 2007
    29,892
    17,556
    YO11 2BD
    Agree rigid pipe is better but if not secured fully it can crack with vibration, as did the one on my last van.
  6. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,345
    34,930
    Our Burstner has a drain tap easily accessible when standing at the offside of the van (matching the description in the handbook). I've never looked underneath to check whether it is connected to an arrangement as in the pic.
  7. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Thanks for the info. I think I'll investigate the hard pipe option and bring the valve to somewhere more accessible. I'll have to check the diameter of the existing Tefen valve.
    The MOT was last October so it must have been okay at that time. I've just fitted 2 new fittings and renewed the wiring and connectors. I've also moved the number plate back to it's poper location- the previous owner had 'fixed' it onto the right hand side of the back panel, annoyingly with 2 small screws, grrrrr! :shout:
  8. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,804
    1,027
    Cark, Cumbria
    Ours has a pull/push handle @ the rear but the outlet just came straight out of the bottom of the tank. Made it very difficult to line up over a grid & impossible to empty where no grid type point was availiable.
    I've modified it so it now has an extending section so as long as I can see the grid is behind me(with the camera)it can reach. Also means I can use it to rinse out the cassette on aires etc. when water is in short supply.
  9. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,594
    22,679
    Narrfoook
    I like that very much Jay ! :thumb:
