Waste water in winter - solution needed
Discussion in 'Motorhome Chat' started by Branston1080, Nov 13, 2012.
  1. Branston1080
    Branston1080 Funster
    Oct 30, 2012
    54
    32
    Here's the issue, how do I manage my waste water tank in winter?
    I work away from home in the week and I have just started using my motorhome as my accommodation.
    I'm on a long term pitch and therefore not moving the van ( no service point anyway).
    My tank is under slung but there is a heated vent to hopefully prevent it freezing. As I'm new to this and have no experience of winter camping I'm unsure of the best way forward.
    Do I keep the tank closed and heated and drain and empty when required or should I keep the tank open so it just drains?
    If I do the latter what's the best container to go for and how do I cope with freezing temperatures?
    I know these are all probably ridiculous questions but I'm worried about freezing pipes/ damage.
    Any suggestions welcome :BigGrin:
  2. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
    To avoid any problems, I would open the outlet on your waste tank, and let it drain into something else, a waste hog, bucket, other plastic container. This is cheaper option than heating the tank etc, and will save you worrying about it.
    • Like Like x 2
  3. f6c
    f6c Funster
    Nov 7, 2010
    3,248
    868
    gloucestershire
    Have to agree with Darklord I use a bucket had no mechanical failure yet:Wink:
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,542
    9,968
    always use a bucket in winter as a closed tank will just freeze solid preventing emptying and potentially splitting as the ice expands:thumb:
    • Like Like x 1
  5. Branston1080
    Oct 30, 2012
    54
    32
    Bucket doesn't fit under
    Thanks for the responses, it looks like the 'bucket' is the way forward!
    Standard bucket too tall to fit under van.
    Is it ok to attach a hose?
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,940
    West Norfolk
    I would just use your tank heating!
    Its the UK, not the Alps! Seriously, I think Knaus's solution to keeping your tank frost-free will be fine.
    Our Chausson has an unheated underfloor waste tank, the bucket only comes out for ski trips.
    Attaching a hose to your tank will just add another thing to freeze.
    Do bear in mind the position of your waste valve though, if remote from the tank, it may freeze if the going gets tough.
  7. scek
    scek Read Only Funster
    Jan 12, 2011
    134
    81
    Manchester
    Bucket with a "small" hole in it.
  8. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Plenty of sites, especially CLs are quite happy if you run a waste hose from your tank into the hedgerow. .. (check with warden/owner first) .. Keep the waste valve open, ensure the hose drains empty and you won't have any problems..
  9. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,916
    11,380
    E Yorks
    If a bucket is too large to go under your van, use a washing up bowl and then just pour the contents into a bucket and chuck-it! :Smile:
  10. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,832
    3,337
    Eastbourne East Sussex
    Have to echo the other comments on here, in freezing weather use a bucket or something similar, not a waste container like a wastemaster as you will not be able to empty it if it freezes. The taper in a bucket or washing up bowl allows it to be emptied even if frozen nearly solid.
    • Like Like x 1
  11. Scout
    Scout Funster
    Apr 4, 2009
    3,299
    8,702
    doncaster
    one of the floppy plastic trug things they expand ,
  12. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    The only problem I had using a bucket was a load of waste water, bucket-shaped lollipops cluttering up a C&CC site's waste diposal drain! :Laughing::Laughing:
  13. Reallyretired
    Apr 27, 2008
    5,832
    3,337
    Don't worry, they'll be gone by spring.:Laughing:
    • Like Like x 1
