Waste tank level sensor
Discussion in 'Tech/Mech General' started by stevec, May 20, 2014.
  1. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    My Sargent control panel has been registering an empty waste tank even though I know it isn't! I took out the sensor and it seems to only have a stub about 2cms long pivoting on the sensor body. Seems something is missing or dropped off. If I put this stub in line with the sensor body (simulating a full tank) the control panel says 100%. Does anyone know if replacements are available. The control panel will only register 0%, 50% or 100% so presumably a three position sensor. I appears to be a pivoting sensor so a bit like a ballcock in operation i.e a hinged float.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,633
    YO11 2BD
    never accurate and even less reliable.
    Not worth sorting out as it will go to pot again very soon.
    • Like Like x 1
  3. buckby
    buckby Read Only Funster
    Sep 6, 2013
    213
    148
    nottinghamshire
    They only show empty or 100% don't know why says so in the autotrail manual
  4. Sunrise Explorer
    Sunrise Explorer Funster
    Aug 22, 2012
    36
    43
    Portsmouth area
    Mine is exactly the same. The supply tank indicator shows 0 - 25 - 50 etc. However the Sargent write up implies that the drain tank only shows 0 or 100% full !
  5. f6c
    f6c Funster
    Nov 7, 2010
    3,259
    870
    gloucestershire
    Pappa John is spot on not worth the bother:Wink::Wink:
  6. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    Just make sure your overflow isn't blocked :Rofl1::Rofl1:
  7. stevec
    stevec Funster
    Sep 24, 2013
    614
    207
    Norwich
    I see the EC200 control panel says 0%, 50% or 100%....but the 50% is optional. theres an input for that but it's not used. So maybe there is nothing missing and the 'float' part of the sensor got stuck. Guess I was expecting a 50% reading. I'll check this weekend. Just booked up a site locally. everywhere seems to be booked up...it must be bank holiday or something.
    • Like Like x 1
  8. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    What !!!!! Again ????? It only seems like 2 weeks since the last one :Doh::Doh:
    :Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
  9. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,576
    10,004
    the sensors generally used in mh tanks, whether waste or fresh tend to be pretty crap. why nobody has produced a cheap diy kit using plastic petrol tank sensors is rather disappointing. it really cant be too hard and would be fairly accurate and reliable. no point to fitting what they currently do
    • Like Like x 1
  10. Allanm
    Allanm Funster
    Jun 30, 2013
    3,147
    4,284
    Cotes d'armor, France
    Mine has 5 sensors, they show 0 25 50 75 and 100. Allegedly! If you remove the tank and clean the sensors, they do for a week or so, then go back to showing full most of the time, and the alarm sounds.
    I disconnected the sensor wiring. Now I empty the waste tank everytime I fill up. Fresh water sensors work fine
    Allan
