I noticed today that my waste water pipe is leaking as is the pipe from the fresh water tank to the drainage valve. Should I change them, with what, or repair it?
I would replace then, you can get flexy pipe from a place that sells pond equipment, for example. This is usually cheaper than M/H spares shop. Just make sure you get the right size!. (take the old ones off first )
Hope this helps,
Cheers, Dave:thumb:
Pond hose, never thought of that good one. Yes it is strange that they are both leaking. The actual tank is fine i have been underneath and checked. Thank you both.
