warranty question
Discussion in 'Motorhome Chat' started by Collyer911, Aug 14, 2013.
  1. Collyer911
    Collyer911 Read Only Funster
    May 30, 2013
    32
    30
    Leicester
    hi all
    ive had my motorhome now for 2 months,
    a couple of things have broken,snapped
    would you think they are covered under warranty?
    1.door lock barrel has come out of lock completely
    2.white plastic clips that hold door in place when open have snapped
    3.again white pilastic clip on entrance door bottom rivet is loose comming out of fitting and will fail sooner than later
    the van is 12 years old but comes with a 12 month dealer warranty
    thoughts please
    thanks in advance
    andy
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Hi Andy depends on what's covered:Smile: cannot hurt to ask dealer :thumb: on the plus side the plastic door clips are about 2 quid ish the door lock could be anything from a tenner to 140 :Sad: and the rivet will be pennies-drill out and rivet back in :thumb: before it works it's way out and enlages the hole :thumb: All ten mins jobs :Wink:
    Terry
  3. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    all the things you list are quite simple to fix and inexpensive so a reasonable dealer will probably sort it. however, they may not be covered as most second hand vehicle warranties are for major failures ( engine , gearbox etc)
    if you dont ask you wont get so telephone the dealer and tell them they are broken see what they say. dont ask the question " are they covered" unless they say they are not, then asak WHY?
    GOOD LUCK:thumb:
    • Like Like x 2
  4. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    On a new van things like this should be covered, but on a 12 year old van I am not so sure - it will depend on precisely what is written down under the terms of the warranty. But they are not big jobs, and arguably to be expected on a 12 year old van.
    I would check the small print first, and then see what the dealer says.
  5. Collyer911
    May 30, 2013
    32
    30
    Leicester
    thanks all
    all the above where what i was thinking
    ive already bought some plastic clips and sikaflex
    i think ill pop it into the dealer and see if he will do the small jobs and pay the labour if not covered
    thanks for your input
    andy
  6. stcyr
    stcyr Funster
    Apr 11, 2011
    1,673
    1,106
    Normandie
    I've said this before, I know, but we bought our 1991 MH from a dealer and were given a 6 month warranty which covered EVERYTHING (from cambelt, which was renewed anyway as a matter of course, to fridge seals and any defect which could develop) with NO quibbles... It wasn't even his MH but being sold on behalf of the previous owner. I would expect nothing less - the whole point of buying from a dealer is to get a perfect MH irrespective of age/mileage etc. Any fault was covered even if abroad, just a phonecall needed to get the go-ahead.
    (Alan at RollingMotorhomes, Slebech near Haverfordwest...)
  7. stcyr
    stcyr Funster
    Apr 11, 2011
    1,673
    1,106
    Normandie
    ... but due to the MH being properly p.d.i'd nothing was needed during the warranty period - or for the following 3 years + except a quick adjustment of the rear brake shoes. ... a month out of warranty and with an apology.
  8. vwalan
    vwalan Funster
    Sep 23, 2008
    7,606
    3,858
    roche cornwall
    while you are there get a few sets of the door clips . you will find that if in sunny climates you will be replacing them every year . i always have a couple ion a draw . mind ido go away for months in winter to hot sunny places i hope . but really they soon get brittle .replaced the door locks on mine only this spring . cost 17 quid thats for complete thing . they do break after awhile if used alot . dont think they really make m,home parts for fulltiming or long terming . good job they are cheap.
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,694
    17,305
    YO11 2BD
    that warrenty was a good deal....many arent so good covering major mechanical breakdown only..and most aint worth the paper they're written on.
    an extreme example....
    cam belt breaks....belt replaced and any associated damege repaired but the belt pulley's and tensioner would not be covered as they were not affected by the belt breaking.
    absolute false economy but thats how many warrenties work.
    i bought a landfover discovery from carcraft.
    on the way home the head gasket blew.
    cause...leaking water pump and thermostat removed by previous owner in the hope it would run cooler.
    the cylinder head was skimmed and associated gaskets renewed but they wouldnt cover the cost of a new water pump and thermostat, even though they were the cause, as they were already defective prior to the warrenty being bought.
    they did pay unknowingly though, as the work was carried out at the garage i worked at and the cost of the covered repairs was 'slightly increased' to cover the cost of the extra parts and labour. though i did pay for the new cam belt and tensioner. :thumb:
    • Like Like x 1
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,350
    9,794
    what most warranties state is that fair wear and tear is excluded, so plastic parts that wear out by design like the door catch would not be covered
    generally when the lock barrel pops out, just grease it and reinsert so it locks back in. if it wont relocate, the handle/lock housing needs replacing as the internal plastic is worn. dealers and locksmiths carry a master type key that can remove a lock barrel by pushing in and turning, so they are not very secure when you think of it
  11. vwalan
    vwalan Funster
    Sep 23, 2008
    7,606
    3,858
    roche cornwall
    most caravan style door locks its held in by a little circlip. i just changed mine buy fitted the old barrel to save having keys cut .
