Warning light, on panel... (1 Viewer)
mark e
242
Rhondda Valleys, S Wales
Year 3 of ownership !
Here's a picture of my control panel in the motorhome.
Link Removed
My problem is the light above the water level indicator, on the right hand side, at the top, which according to my manual is
" when the waste tank is full ".
But it's empty !
Could it be a " short circuit ", as my panel is off, but the light stays on. Tried leaving the external tap open, closed but to no avail :Angry:
Any suggestions ?
haganap
12,758
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
But it's empty !
Any suggestions ?
Hi Mark
On our CI we would often be faced with that. Get underneath and you will see a connector on the bottom of the waste tank. Most likely problem is crud on it. Unplugg it clean it and plug it back in result should be problem solved.
