wallcoverings? (1 Viewer)
lee52
327
119
tyne and wear
selfbuild
newbie
Well the ole bus interior is starting to get to the stage of thinking about wallcoverings and colour schemes etc.. the OH is starting to get involved with the bus now. options wise I have are buy the proper prefinished wallboards and stick over the fresh ply lined bus, cons been the extra weight and it will be expensive (this is a budget build) would need 22 sheets of 8x4 to do walls and ceiling, carpet the walls and ceiling, or wallpaper.
The OH has seen some wallpaper she really likes has anybody wallpapered a MH if so what prep would be needed would the plywood lining need sealing first (was thinking matt varnish the lot) what sticky stuff would you use normal wallpaper paste or pva. and will there be any problems with it as there will be more temp and moisture fluctuations than a normal house.
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
Have you thought about hollow PVC cladding?
300mm or 400mm wide, comes in a variety of finishes and not too expensive.
We did the roof in the Mercedes with it and were well pleased:
Broken Link Removed
Broken Link Removed
Broken Link Removed
Peter
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
I like the PVC cladding idea ,lightweight and moisture resistant also can be wiped clean .
If your going down the ply route 22 sheets of 8 by 4 will add a fair bit of weigh so go for the thinnest sheets you can .If you cover them in a pva solution you will be able to use wallpaper and then your options are endless ,whatever you do good luck and be sure to post a few pics.
Vlad
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
not used in MH but @Terry put me on to the hollow PVC boarding, just done our en suite shower room at home, wall covering area 30m2 £300 done in a day (y)
L
lee52
327
119
tyne and wear
selfbuild
newbie
Peter
what did you use to fasten the pvc boards up with
L
lee52
327
119
tyne and wear
selfbuild
newbie
Vlad
the bus is already fully lined with 3.6mm external ply
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
with the area you have got to cover i wouldbe using a combination of finishes for the different areas pvc wall boards in baths and kitchen areas carpet in lounge soft areas and wallpaper on any big areas
Minxy
32,649
66,541
E Yorks
Carthago Compactline
Have you thought of vinyl flooring? As you've already got boarding it would be just a matter of sticking it on ... we actually looked at buying a house once many moons ago where the owner had put it on the walls in the bathroom and it actually looked really good and was quite practical too.
With the different colours/patterns available nowadays you could make it look very good for very little.
L
lee52
327
119
tyne and wear
selfbuild
newbie
I was planning on using vinyl flooring for the toilet/shower room.
now thinking pvc cladding for the ceiling and wallpaper the rest
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
Hi you can get 3 mm finished ply for around £16 a sheet 8 x4 ft(y) It works out a bit cheaper than the PVC Cladding but cladding is great for wc/shower walls -Also the cladding weighs a little more than the ply =£5.50 per 250 mm x2700 per sheet-Veltrim (carpet) for walls is easy to cover big awkward areas but not to my liking -10 x 2 mtrs long/wide=105 inc 10 cans of spray glue
Wallpaper ?? but decent vynil is around £7 ish a roll and you would get 3 drops per roll around 500 mm-ish wide
terry
Minxy
32,649
66,541
E Yorks
terry
As you've said wallpaper isn't cheap nowadays, not for anything worth having unless you can find some on reduced that will suit, it won't be as durable either as proper boarding, cladding or vinyl.
Peter A Forbes
270
184
Mercedes 614D
We fitted hardwood stringers down the length of the van and with a starter strip/channel for the first one, we screwed each open flange to the strips, then pushed the next one into the opening. We did a trial fit first with some offcuts.
Broken Link Removed
Broken Link Removed
Broken Link Removed
We used pozi button flange stainless steel self tappers.
Peter
