Voltage for Idiots (3 Viewers)
ShiftZZ
21,383
84,555
Dark Side of the Moon
Right, fellow funsters,, here is my second question of the day,,,
We are as most of you know the owners of a Rapido and we have had two solar panels (80W) and an extra battery fitted.
We now have two, yes TWO things that I can press to find out the Vots, amps, sunlight hours, the temprature in Mumbai etc. BUT. What does it all mean...
Volts, what is Good, bad, fire up the engine?
Amps. lost on me.....
Watts - Yep that got me, we were kicking in some 120+ in Northern France, far better than watching TV, up and down went the Watts.
So come on you techie heads, spill the beans...
Oh yes the temp in Mumbai was made up....
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Take care watching the solar regulator Dave...It becomes addictive. I cant walk past it without checking whats happening:ROFLMAO:
Aug 27, 2009
19,788
23,069
Hertfordshire
Van Conversion
40 years
Voltage is the potential to cause current, to cause something electrical to happen. A 12 volt car battery has 12 volts of potential. Nothing happens unless that battery is connected to something, like a headlight bulb. A 240 volt household outlet has potential, but nothing happens unless you plug something into that outlet and turn it on.:ROFLMAO:
Current is the flow of electrons. When you connect that battery to that headlight bulb, current flows, which causes the light to turn on. :ROFLMAO:
Resistance is the ratio of the two, R = voltage divided by current. If the bulb has 4 ohms of resistance, then the current is I = E/R = 12/4 = 3 amps.:ROFLMAO:
The power used by the bulb is voltage x current, in this case, 12v x 3 amps or 36 watts.:ROFLMAO:
Re shock, it takes 10-20 ma of current (0.020 amp) to cause a shock and possible death. but that current is caused by a voltage, and the higher the voltage, the higher the current, and the higher it hits.:smalllove::smalllove:
ShiftZZ
ShiftZZ
21,383
84,555
Thanks for that Buttons, but can I stress,,,, Voltage for Idiots
canopus
6,139
10,255
rural Lincolnshire
Carado CV640 Pro
Since 2010
Are you a member of the IET per chance? :thumb:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
For me all I need to know is the voltage of my batteries. Never allow them to fall below 11.5 according to my handbook so I never allow them to fall below 12v.
If you let the batts fall below 11.5 the chances are you will damage them.
Hows that Hilda? :thumb:
ShiftZZ
ShiftZZ
21,383
84,555
Great, at least you understood the 'Voltage for Idiots' bit.... So can disregards the 12.4v being 50% and the 12.26665543335676v being fine for bacon rolls, gas mark V etc....
Why cant they make a meter that states Yes ok or Not a hope
Aug 27, 2009
19,788
23,069
Hertfordshire
Van Conversion
40 years
Because the first question you would ask is.....what does that mean. Why cant they give me more info so I know what is happening. :cry::Confused::Confused::Confused::drink:
Mar 29, 2010
438
208
Hebden Bridge
Moto Trek Xcite EB
Since Sept 2011
My 1998 Hymer has a red light that comes on when the voltage gets too low, I would guess your Rapido will have one too somewhere on the control panel.:winky:
ShiftZZ
ShiftZZ
21,383
84,555
Sorry to confuse Buttons me old mate. We have sat there Boggle eyed keeping tabs on that meter....
"Look its dropped to 12.5v, switch off the last remaining light, get the torches"
I think I need to cover it up, we cant live like this, chained to the V meter. I may have to invest in an iphone app so that I can monitor it remotely and have an e-mail sent if the damn thing falls below, 12.2v.
We may have to sell the TV so that we can manage the extra Watt/Amp/Volt/Kelvin whatever. Its driving me and Mrs ShiftZZ and Snowbird ga ga..
So as it stands if we stay above 12v we are fine?
ShiftZZ
ShiftZZ
21,383
84,555
Red light, Jeeze I will have to watch that as well....
ShiftZZ (Searching for iphone app and red light - (some strange results obtained, what has Amsterdam and Bangkok got to do with my Rapido????)
Aug 27, 2009
19,788
23,069
Hertfordshire
Van Conversion
40 years
When Mrs ShiftZZ is having a shower in the van, and you are doing the washing up. Does she scream when you turn the tap on full.:Eeek:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Gonna have to butt in here ShiftZZ.
If you had a bucket full of water sitting on your kitchen worktop and this bucket had a tap at the bottom of it. The water is the potential.
Now if you stand real close and open the tap the potential will shoot out all over your trousers, this is the flow or current.
Now potentially anyone who looks at your trousers for the next hour or so will think you have a weak bladder, this is known as a bloody good laugh, and if they make mention of it in a derogatory fashion this is known as a P*ss take...............Okay now.
............................Griff..............
:thumb:
ShiftZZ
ShiftZZ
21,383
84,555
Gootcha there me old Popeye....
Colostomy bag in wellies keeps feet warm, no more embarresing wet patches.
Anyhow, you are just trying to confuse me..
So 12v or 12.1v or better is ok? Right?
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
................Right
Aug 27, 2009
19,788
23,069
Hertfordshire
Van Conversion
40 years
Rubber boots and rubber gloves for the incontinent electrician. Sounds like safe working practices. :rain:
ShiftZZ
ShiftZZ
21,383
84,555
Is this a reasonable chart?
Less 10,5V: - battery fully discharged, all user-/consumers must be turned off !
10,5V bis 11,5V: - battery fully discharged user-consumption should be limited
11,5V bis 12,2V: - normal operating condition at 12 V during energy usage
12,2V bis 12,5V:- well-charged battery
12,5V bis 12,8V:- battery fully charged
12,8V bis 14,2V:- no energy being drawn from battery
more than 14,4V:- condition reached only by over-charging
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Not quite IMHO Hilda
11.5 or less turn everything off until recharging is possible. (or risk damaging batts)
14.4 just means your battery is on charge whether that be hook up. solar or engine.
novawight
627
232
Hayling Island
hi top,
on and off 50 years
Don,nt bother with all that amps and volts malacky, got no solar power or sat tv, if some thin aint working, just get it fixed or get a new battery, it seems to me everything is getting to technical, i,m only after a bit of camping and a chat with friends:Smile:, and of course a bevy or three.......Del
Heyupluv
3,862
1,593
France,
touring many years..42+
Just to throw another question on your thread Dave how many watts does a large fridge and freezer in a motorhome use when its drawing current / power(on):Eeek:
ShiftZZ
ShiftZZ
21,383
84,555
I bet the answer is 75hp at 4 Amp at -27oC, 13.7v, 12Kelvin. I'm going to stick with that,,
