gerry mcg
the Victron 15/75 MPPT solar controller seems to have 3 options, set by a jumper - these are
1.3 Battery Life: intelligent battery management
When a solar charge controller is not able to recharge the battery to its full capacity within one day, the result is often that the battery will continually be cycled between a ‘partially charged’ state and the ‘end of discharge’ state. This mode of operation (no regular full recharge) will destroy a lead-acid battery within weeks or months.
The Battery Life algorithm will monitor the state of charge of the battery and, if needed, day by day slightly increase the load disconnect level (i.e. disconnect the load earlier) until the harvested solar energy is sufficient to recharge the battery to nearly the full 100%. From that point onwards the load disconnect level will be modulated so that a nearly 100% recharge is achieved about once every week.
I’ve a Schaudt EBL 119 with AGM leisure batteries, what charging mode should the solar controller be set to?
- No jumper: BatteryLife algorithm
- Jumper between pin 1 and pin 2: conventional (see 1.2.1.) Low voltage load disconnect: 11,1V or 22,2V - Automatic load reconnect: 13,1V or 26,2V
- Jumper between pin 2 and pin 3: conventional (see 1.2.1.) Low voltage load disconnect: 11,8V or 23,6V - Automatic load reconnect: 14V or 28V.
