- Nov 7, 2015
- 497
- 469
- Autosleeper Broadway
- since 2015 previously caravaning 25 years
At the moment we have an 80 watt panel factory fitted by Autosleeper and a basic 10amp solar controller along with a 200AH of leisure batteries, the charging is then controlled by the Sergeant power supply that charges the vehicle and leisure batteries as required.
On a good sunny summers day the panel gives up to 4 amps at best, but at this time of year less than 1 amp which isn't enough to keep the batteries topped up when parked.
To improve matters I was thinking of fitting a Victron MPPT 75/15 controller regulator and a Battery Master, then when the weathers a bit warmer fitting another 100watt panel, if required.
As the Sargeant EC500 has a limit of 120 watts I couldn't run both solar panels through the EC500.
Another option would be to use the same type of controller as Techno uses Link Removed which has a bonus over the Victron in that it has its own display
So the question is, is there a better method without the need for two MPPT controllers ?
Any advice most welcome.
Chris
p.s we also have a Sterling B2B charger which is great !
Chris
