Very usefull product for fixing things!
Discussion in 'Motorhome Chat' started by Johns_Cross_Motorhomes, May 17, 2009.
  1. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,420
    5,442
    East Sussex 01-580-881288
    Many months ago I bought a Kilo of this stuff as it intriqued me!
    You put some granules in hot water and they 'melt' together to form a sort of plasticine, which can be formed into many shapes or used to build up a broken part.
    When it gets cold it turns rock hard, can be re-used time and time again.
    Today I noticed the end of a curtain rail had AGAIN pulled out of the wall despite several attempts in the past to wallplug it. Unfortumately behind the plaster is a concrete lintel and it will not drill vey far in so the plug is mainly held by and inch or so of plaster which does not hold plugs very well.
    Had a small brainwave, remove plug, ram some of this stuff into the now 'ragged' hole and screw in screw.
    Polymer went rock hard, screw is in so tight I cannot turn it any more. job done!
    This stuff I think could have many uses in MH's and around the home, well worth buyiing some.
    Polymorph Thermoplastic Granules 100g
    Peter
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,856
    6,109
    Mansfield,Notts
    Peter you have used this product in an unauthorised manner not included in the list of suggested uses, you have been reported to Polly Filla and the building regulation enforcement dept for sanctions to be taken as deemed fit
    <LI class=main>Mini Moulds for casting RTV Silicone in minutes! <LI class=main>Handled caps for screw to bottles and jars for easy opening <LI class=main>Prototyping & Engineering Components <LI class=main>Mounts for RC motor drives and gearboxes <LI class=main>Modelling Animals and General Creativity <LI class=main>Fishing Tackle Rig & Fly Ties <LI class=main>Fast Set Adhesive <LI class=main>Replacement RC Model Parts <LI class=main>Remake Injection Moulded Parts <LI class=main>Repair for Tools & Handles that have broken Wrist and Thumb Supports
    Bodging Curtain Rail Mounting screws
    My apologies there it is at the bottom:Doh::Rofl1::Rofl1::Rofl1:
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,420
    5,442
    You can make hand made DUMMIES with this as well Geo:thumb: You had better buy some, actually I think it has many uses!
    Peter
  4. Losos
    Losos Read Only Funster
    Feb 17, 2009
    550
    4
    Suffolk & Czechland
    Hi Peter,
    Thanks for posting this, I have used epoxy putty in the past for similar jobs (Those window lintels are a b****r aren't they :RollEyes:) Milliput being but one of the brand name.
    But this polymorph stuff sounds even better. I have seen it in various catalogues but seemed a bit pricey and being a tight arse and with no immediate need I didn't get any.
    Can you tell me what the box says about shelf life 'cos I seem to be throwing a lot of stuff away lately that I haven't used within the prescribed life :Sad: and it's gone all yuky and unuseable.
    Just chucked a tin of fibreglass gel away, it was almost solid, mind you it was ten years old :Rofl1:
  5. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,420
    5,442
    Hi it does not deteriorate, I keep in in an old coffee jar, its waterproof, does not stick to anything, mine must have been in the garage for months.
    You dont mix it with anything, just put it in hot water, when it cools, just goes solid, stick it back in hot water, goes pliable and use it again!
    Bit pricey but you dont need a lot!
    Peter
  6. Losos
    Feb 17, 2009
    550
    4
    Suffolk & Czechland
    Thanks Peter will definately put it on my next order.
  7. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    Thanks Peter, looks very useful.
    I did a Google search and found there are quite a few people selling similar stuff on eBay. Maplins have it as well but heck of a sight dearer.
    Graham
  8. davejen
    davejen Funster
    Aug 21, 2008
    1,268
    722
    Kirkpatrick Fleming Dumfries
    Hi, Peter, hope you don't change your curtains a lot- how are you going to get the b+++++ out again?!!
    Cheers, Dave:thumb:
  9. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,420
    5,442
    Easy just undo the wood screw, better than a rawplug:thumb:
    Peter
