vertical ripples in bodywork (1 Viewer)
nannyjan
125
56
Forest of Dean, Glos
Coach built
New end of March 2010
Just wondering if anyone knows what is causing several vertical ripples in the bodywork of my motorhome. My motorhome is two years old at the end of May and I will be having the habitation check done to keep the 5 year water ingress waranty valid. Do you think that water ingress could be causing these ripples. Any advice appreciated.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I would get in touch with the supplier NOW, could be delamination, unless you are in the habit of driving it into a brick wall.:ROFLMAO::ROFLMAO:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Our Elddis had ripples too!
I think it is because the aluminium skin has a high expansion coefficient. When it gets warm, it wants to expand but has nowhere to go!
I might be wrong on this, but it seems feasible!::bigsmile:
As for water ingress causing it, I would say it wouldn't be a factor unless the ripples are in the shape of the wooden frame beneath!:whatthe:
N
nannyjan
125
56
Coach built
Ripples
A photo of your ripples may be useful....::bigsmile:
Hi Callum, the ripples wouldnt show on a photo as you can only see them when standing at a certain angle and catching it in the right light. But thanks for your advice. I am going to take it back to the dealer asap as the more I look at it the more I think it is cause for concern. Many thanks Jan
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Is it rippling where it sticks to the side batons IE in-between the batons ?I do know some makes do not stick the roof and let it flap but this does not happen to the sides.Take it back a see what they say ? (if not happy with explanation)also get a second opinion on it from a caravan/mh repair shop :winky:THEY SHOULD GIVE FREE QUOTE /ADVICE
terry
43,323
49,440
if its only visible at certain angles and light conditions i would say theres nowt wrong.
it will be where the outer skin is glued to the side wall frame which will never be totally flat over such a large area
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Gently push where the ripples are...
If there is give, or slight movement definately "Delamination...:Smile:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
from certain angles you can see the shape of the timber frame on mine too
just put it down to contraction of the ali skin maybe i'll look more into this now.:cry:
