- Nov 7, 2015
- 497
- 469
- Autosleeper Broadway
- since 2015 previously caravaning 25 years
I've now fitted two of these kits which don't work as I expected.
The first kit started running when the ambient temperature was only 20°C and cycled on / off every 5 seconds, adjustment of the trim screw made it run constantly !
I fitted a complete replacement kit today.
With the fridge switched OFF the fan switch in auto mode and an ambient temperature of 22°C the fans were still but as the temperature around the fan thermistor sensor hit 26°C the fans started then as the fans cooled the thermistor the fans stopped, but within seconds the fan motors began to emit a high pitched squeal before starting to spin again and continued to cycle in this way on off squeal on off
Adjustment of the trim screw only varied the fault by 1°C
The high pitch noise definitely does not come from the control box
Have I received two faulty fan kits or is there another reason, any suggestions welcome.
Thanks in advance !
Thanks in advance !
