Veneer on doors/cupboards
Discussion in 'Motorhome Chat' started by durhamahoy, Aug 26, 2013.
  1. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    Hi,
    The veneer facing on some of our cupboard doors/bathroom door seems to be coming loose where it wraps around the sides.
    Has anyone else had this problem?
    The van is 2001 so we expect some wear and tear, what do funsters think is the best adhesive to stick the edges back down with. I don't have a good track record with super glue !!
    Any help much appreciated
    Steve
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,334
    5,338
    East Sussex 01-580-881288
    Get some brown paper or plain paper, place over lifted parts and apply pressure hot iron, this should melt the original glue and refix.
    Peter
    • Like Like x 2
  3. Gooney
    Gooney Funster
    Jun 2, 2010
    4,766
    7,853
    Flintshire
    Evo-Stik contact/impact adhesive is probably what you need, you put a light film on both surfaces and when touch dry bring the surfaces together, sticks like do do to a duvet:thumb:
    • Like Like x 1
  4. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    Cheers Peter,
    Will try this before I get the glue out.
    Steve
  5. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    If using the iron doesnt work....try the same technique but put some "wonderweb" between the two pieces of wood first...
    You used to be able to get "animal glue" on like a roll which was very thin and did the same job but I haven't seen it in years...
  6. newboy
    newboy
    Sep 28, 2009
    6
    South Lincolnshire
    Are your cupboard doors veneered? The doors may look grained but could possibly mdf with a melamine reverse with a foil that wraps around the front and along the edges. If so it could be bad news. The industry has had a problem with the foil coming loose after a few years. It was adhesive problem reacting with the mdf. If this is the case you can only bodge them up. The foil will eventually come off.
    Sorry if this is the case.
    Stuart
