Vehicle Weight
Discussion in 'The Beginner' started by Shell181, Apr 18, 2010.
  1. Shell181
    Shell181 Funster
    Apr 11, 2010
    101
    11
    Lincoln
    Hi everyone, just thought I would update you on our search. We went to quite a few dealers yesterday looking for the layout that would suit us. We found 2 which we really liked the layout of (differing from some of our requirements again lol). The Laika Ecovip 400 and the Luna Roadstar 726.
    We are resticted to 3500 Kg Vehicle Weight as hubby is a diabetic.I have been searching frantically today to find out what these MH's are and cannot find what I need. What is this information called please when looking at advertisements on the internet because I understand it all but when looking for the info it doesn't seem to be as simple as 'vehicle weight' is it known as something else that it may be under?. Does anyone know please?
    I suspect if I do get any answers that it won't be what we want to hear lol because they are the layout we would like, but at least I can stop thinking about them then !
    Thanks for any help
    Shell
  2. wireman
    wireman Read Only Funster
    Dec 18, 2007
    148
    Chesterfield
    Maximum Authorised Mass or MAM for short. Used to be known as MLW or maximumweight Laden.
  3. wireman
    Dec 18, 2007
    148
    Chesterfield
    the Laika 400 comes with the choice of either 3500kg or 4200kg MTPM
    Weights
    •MTPLM**: 4000 (78.8 CWT)
    •Mass in Running Order: 3375 (66.49 CWT)
    •Maximum User Payload: 625 (12.31 CWT)
    MTPLM is the same as MAM I belive, son the Lunar is out for you unless you have it downlated but then you will only be able to carry 125 kg of kit which won't go very far at all...
    The Laika could be either, you would need to check with vendor.
  4. Robinhood
    Robinhood Read Only Funster
    Mar 7, 2010
    159
    Sherwood Forest
    What you are looking for may be expressed as GVW (Gross Vehicle Weight) or MAM (Maximum Authorised Mass).
    If you are looking for what are essentially quite large 'vans for a maximum weight of 3500kg, also be aware that your payload (what you can load in the 'van from empty) may be pretty low (some models are better than others), to a point where it renders it impossible to carry enough to enjoy the lifestyle.
    Opinions vary, but I would be looking for a minimum of 500kg (after full fuel, water and 75kg for driver) to allow for two people to live reasonably. Most 'vans nowadays will quote their empty weight as well, to roughly the same spec, as I've put above - but older 'vans may be different, so take care.
    Good luck.
  5. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,494
    894
    South Glos
    Hi Shell181,
    You don't say what year the Lunar 726 is.
    The early vehicles (upto 2002/3) were built on a Fiat Long wheel base chassis and were rated at 3500kg with a payload of 680kg.
    In 2004 they were restyled and the weight down rated to 3400kg with a smaller payload of 500kg
    In 2005 they were built on and ALKO chassis and MMM shows that the weight was then 3500kg with a payload of 418kg - I would check the weight plate on the vehicle because I think there may have been an option to upgrade to 3850kg
    The very last version made in 2008 were rated at 4000kg.
    So if the one you are looking at is older then it may be within your limit.
    But whichever vehicle you choose be sure to check the vehicle plate and any converters amendment to assure yourself of the weights.
    Hope this helps
    Lunarman
  6. warwick
    warwick Read Only Funster
    Sep 16, 2008
    113
    Be aware Lunar no longer produce Motorhomes which can make assistance with problems and spares more difficult.
  7. Shell181
    Shell181 Funster
    Apr 11, 2010
    101
    11
    Lincoln
    Hi Lunarman it is a 2005, so maybe still possible, it was out of our price range but maybe an older one with the same layout might be ok then :Smile:
    Thanks for the info Warwick
    Shell
  8. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    don't forget that if you find something you like over 3.5 you can have it downplated to your limit ....don't forget to SEE it weighed before you buy to ensure that you would have enough payload , trust no-one on this
    I have a payload of 450Kg , and manage ...just ..with that , no bikes/motorbikes etc , 1 13Kg bottle of gas + small emergency reserve , only 6 pairs of shoes for my wife ; trips up to 4 months
  9. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    When viewing a MH is is quite reasonable to ask to see the manufacturer's or converter's plate giving the necessary information. By law the MHs must have a plate giving such weights (masses?) as MAM, gross train weight and axle loads.
  10. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Laika can take a while too!
    Try to stay with uk manufactuers - that way parts won't take 6 months to arrive!
  11. oldun
    Mar 23, 2008
    748
    160
    St Neots
    The trouble with down plating is that for every the MAM is reduced then the payload is also reduced by 1 kg.
    As most MHs have only 500 kg or so payload then the scope for reducing the MAM is limited.
  12. Gonewiththewind
    Gonewiththewind Read Only Funster
    Sep 13, 2007
    854
    35
    Lancashire
    Here's another. P.T.A.C. As the figure is the same as the G.V. or the M.A.M. There fore I assume that PTAC is French for The Gross Weight.
    Don
  13. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,680
    14,537
    North Lincolnshire
    lebesset,
    Only 6 pairs of shoes!!!
    My management would consider that grounds for divorce.
    Once took 10 pairs of shoes (for different outfits) band 6 handbags for a 7 day break.
    Me: 1 x flip flops, 1 x trainers, 1 x wallet. Done.
    Apparently "travelling light" only applies to me.
    John
