Vehicle Electronics
Discussion in 'Tech/Mech General' started by snuggly wuggly, Jan 10, 2016.
  1. snuggly wuggly
    snuggly wuggly Funster
    Apr 29, 2014
    29
    16
    Hi All
    Our Injector Light has appeared on the dashboard (2001 Hobby 750 Fiat Ducato) no loss of power, after going to several garages including a Fiat one, to get the computer re-set ‘ODB2 Port’, we eventually found a lead which generates it's own power, so with the new plug the computer now recognises the problem but has created another one!!! It’s NOT the Injector Light as shown, it’s an Engine Fault, so when plugging the computer back in with the new lead it now shows ‘Cooling fan low speed fan relay P0480’, so after that long story, does anyone know where it’s located?!!
    Any help would be greatly appreciated.
    Tony
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,758
    23,211
    Narrfoook
    What happens if you just reset it ?
    Does it come back ?
  3. holdsworth ranger
    holdsworth ranger Read Only Funster
    Nov 12, 2012
    11
    4
    normanton
    hi there
    there are 2 fan relays, a low speed and a high speed, in a box near the centre/top of the radiator.They are controlled by the engine ecu.First pull the plugs and give them a good soaking with contact cleaner.
    Cheers - mike
    • Like it Like it x 1
  4. snuggly wuggly
    Apr 29, 2014
    29
    16
    Thank you both for your reply, yes it just comes up with P0480, I'll take a look tomorrow, thanks for that.
    Tony :)
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,122
    17,789
    YO11 2BD
    Its never that simple.
    The code description may show cooling fan relay but it could be caused by a myriad of problems shown below.
    The generic code for fans is p0480
    For the low speed fan its code p0481 and for the high speed fan its p0482
    The causes for this DTC may include:
    Faulty fan control relay 1
    Fan control relay harness is open or shorted
    Circuit electrical connections poor
    Faulty cooling fan 1
    Faulty coolant temperature sensor
    Fan cooling fan harness is open or shorted
    Cooling fan circuit poor electrical connection
    Intake air temperature (IAT) failure
    A/C selector switch
    A/C refrigerant pressure sensor
    Vehicle speed sensor (VSS)
