Vehicle battery problem (1 Viewer)
Sep 20, 2014
155
36
Luton
Coach built
8 years
I have autosleeper Cotswold
We are parked on site with electric hookup in spain for last 5 weeks yesterday couldn't start van as battery was flat I'm confused as to why or what I'm doing wrong or not doing right
Sensible answer will be appreciated
Comical ones accepted
RowleyBirkinQC
2,347
226,714
Dazed & Confused
Can't speak from experience of your van, does your charger have a battery select switch (habitation / vehicle) denoting which battery gets charged? Could you have been inadvertently using the vehicle battery as a habitation power source? Some form of constant drain? Do you have a battery master or similar to keep vehicle battery topped up when leisure batteries are fully charged? How old is the vehicle battery, could it be nearing end of expected life? Do you need to turn the van charger on in addition to being on electric hookup?
Unlike I, I'm sure someone who knows what they are talking about will provide guidance soon. Good luck!
Pia
855
725
staffordshire
Adria Coral Supreme 680ST
...someone will pop along shortly to give you an answer....I've been thinking we must replace our starter battery before we leave for Spain in a couple of weeks....it doesn't seem to be quite as healthy as the habitation one and seems to have a lower charge read out...we've had our MH only for a month and next week we'll try wild camping to try it all out...hope you get the answer to your query here before long.:)
Jun 29, 2015
3,475
57,383
Southampton
caravan (for now)
on and off since 1984
If you have been parked for 5weeks without starting the engine, the starter battery will have discharged. You need to put the battery switch to vehicle to charge the starting battery once a week
Apr 29, 2014
462
253
Warwickshire, UK
Chieftain
Since 2004
Can only reply from my past experience I now have a battery master but previously my battery kept dying ( only year old) so thought must be a drain heard on here radios are often the culprit so took fuse out hey presto when I had van serviced he told me it was a drain easiest thing now when not in use press button to release front of radio never had problem since but of course yours could be different hope you get sorted
RowleyBirkinQC
2,347
226,714
Dazed & Confused
The Autotrail we used to have had a reversing camera with a power switch in the cupboard with the Sargent charger and entertainment system gubbins. If we forgot to turn that camera off it would drain the battery.
Jun 17, 2012
2,932
9,920
North Essex
Autotrail Delaware
>12 but <13
Do you have control panel set to smart charge or leisure only?
Panel can be set to charge either or both batteries, on mine I can choose which battery to charge or use.
If you can, set panel to charge vehicle battery.
andy63
4,672
15,017
south shields
None
since 1990
It sounds like you have no facility to charge the start battery when on hook up ,or if you have it was never selected...
Someone has already mentioned a battery master type device which will provide a small charge current (usually 2 to 4 amps) to your start battery once the leisure batteries are up to voltage...
That seems like a good option for you to prevent same thing happening..
Andy
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
You will have a Sargent controller on your A/S Cotswold, go on the Sargent website and put your controller in and get the instructions, and it will tell you how to set up your charging system.
Mine is an EC480 if yours is the same I can tell you how to set it up, there is no need for a battery master on your van as you can set the controller to Vehicle, Leisure or Smart charge which charges what ever batteries need first.
John.
Ps found link Link Removed
