Vehicle battery flat
Discussion in 'The Beginner' started by camel, Jan 28, 2012.
  1. camel
    camel Funster
    Apr 25, 2010
    31
    4
    Durham
    Hi, my first post as I usually find an answer to my query by patiently looking through previous posts. Our motorhome is in storage and hasn't been started for 8 weeks, went today and battery is flat and won't 'turn over'. This is our first motorhome after hiring previously, and first time of shutting it down for the winter. We have a Bessacarr E560, 5 months old and did not expect the battery to be flat already even though it hasn't been used. Is this normal and do I need to keep turning it over each week to prevent this? Looking forward to be more involved in your excellent forums, thanks, Paul
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    East Sussex 01-580-881288
    The alarm system ect will draw current and can flatten batteries, if you are stored in the open, use one of these to keep the battery topped up.
    Caravan Motorhome Solar Panel Battery Charger 12v
    Peter
  3. Enjoy_Yourself
    Enjoy_Yourself Read Only Funster
    Jul 1, 2010
    86
    25
    Pontypool, South Wales
    Try disconnecting battery when you are not going to be using for a while (as long as this won't void your insurance when the alarm is disconnected). I am looking at fitting a battery isolator to make this easier as getting to the battery on a Ducato is a bit long-winded.
    Even if you turn it over for half an hour each week this doesn't seem to put enough charge back in. If you can get it connected to EHU for a couple of hours each week this might help, but I am guessing that this is not an option if in storage.
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    If you disconnect battery, make sure you know the radio code !
    Peter
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    Get a REAL solar panel not a cigar lighter dash mount no watt job :Rofl1:
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,214
    7,337
    Nr Watton in Norfolk
    This looks to be a great little product but check first that your cigarette lighter or 12v socket is still live with ignition turned off. Many, including our Pug Boxer are disconnected when you turn off the ignition and so the solar panel will not work without some wiring work.
  7. K9Brian
    K9Brian Funster
    Aug 2, 2010
    612
    608
    South Manchester
    Battery will drain down due to engine management, radio, alarm, tracker etc. Once its flat it will need a couple of days charging to get it back to 100%. Short runs or bursts from a generator won't get it back to full charge. Removing the negative lead will stop the drain but you'll lose radio settings etc and if you have alarm or tracker fitted it could mean your insurance is invalidated. In my situation even a solar panel will not provide enough charge in the winter months. I have a spare battery which I alternate in the winter months which allows me to bring the vehicle battery home for a good top up. It's also a good idea to give the van a run every couple of weeks to get the oil circulating and to remove rust from the brakes.
  8. Techno
    Jul 28, 2010
    14,107
    14,921
    There is an easy mod you can do in the nearside fusebox to make it live full time. X244 chassis etc
    [​IMG]
  9. icantremember
    Sep 2, 2010
    5,214
    7,337
    Is that to keep the fag lighter live?
  10. Techno
    Jul 28, 2010
    14,107
    14,921
    Yes can do same for fag or accessory socket but I chose to feed the accessory cos my sat nav gets upset every time it loses power. Both in left fuse box
    • Like Like x 1
  11. Techno
    Jul 28, 2010
    14,107
    14,921
  12. icantremember
    Sep 2, 2010
    5,214
    7,337
  13. Techno
    Jul 28, 2010
    14,107
    14,921
    Just a note for the viewers. Do not do this with more modern models that use CANBUS wiring.
    Fine for 2006 and earlier and common across Peugeot Fiat etc.
    ALSO I posted this on another forum so I've copied it for those who it may effect
    My 2004 boxer has never had both 12 volt cab sockets live since I bought it.
    I finally had time to investigate more thoroughly having failed to solve the problem last time.
    The answer was incorrect information in the owners handbook, as well as quite a loose fitting fuse on the 15 amp for which I just squeezed the holders closer together.
    The cigarette lighter is listed as fuse 44 15amp and the power socket as fuse 52 20amp, this is actually completely the opposite in reality.
    The power socket marked 180 watt maximum is fuse 44 15amp and the cigarette lighter is 52 20amp. The wiring size to each corresponds correctly with this.
  14. icantremember
    Sep 2, 2010
    5,214
    7,337
    Ooops.....that's bu**ered it, mine is 2010:cry:
  15. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    89
    Plymouth
    Hab Bty
    Talking about bty's We stopped on an Aire yesterday en route to Spain and overnight the hab bty was drained. Nothing was on bar for lights to cook and read for awhile ! Is it possible to test a bty to see if it holding its charge' If it is kaput which make of bty would you recommend> I have an 09 Auto Sleeper Sigma and wondered if the bty has had its day etc.:Angry:
  16. LouiseL
    LouiseL Read Only Funster
    Feb 8, 2012
    new york
    Well, battery is one of the most important parts of our cars. I read an article entitled The basics of the battery that runs your vehicle. It says that an automobile battery has to serve numerous functions, but the majority of us rely on it to start the automobile every single day, which is really true. The numbers and marks on a battery can help you keep apprised of the state of your vehicle's health.
  17. ericonabike
    ericonabike Read Only Funster
    Jan 19, 2012
    430
    267
    Leicester
    Similar, but with added EHU...
    For the past couple of weeks my Autocruise Starburst [bought a week earlier...] has been hooked up to the mains on the drive. I was concerned that despite my best efforts not all water might have drained from t'system and so I have a convector heater in there on frost setting, with the mains switched off during the day. Today I thought I'd start it up, just to check that it would really - and it didn't. Certainly not first time. I checked the info on the - what do you call it? Control panel? and it was showing 12V 'good' for the leisure battery and 11.7 V 'fair' for the vehicle battery.
    I switched the mains back on and the vehicle battery then flickered between 'fair' and 'good'. The van then started up normally.
    Does this suggest the 6-year-old battery is dying? I thought the van charged both leisure and vehicle battery when on EHU.
  18. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,755
    3,255
    Eastbourne East Sussex
    Battery has probably had it. Many only last 3-5years though the one on my Suzuki 4x4 is 8 years old and still going strong.
    I wouldn't consider 11.7v to be 'fair' however 11.7v with no load is 'dead'
  19. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    All vans are different, most will charge both provided the correct swtich setting are selected, some can only do one or the other and you have to manually switch. A battery master will overcome that problem
  20. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    I blame the Brownhills storage area at Birtley. Went to get my MH yesterday & found the vehicle battery was flat - I think they have been nicking the charge for their own vehicle batteries ! :Smile:
    • Like Like x 1
