Vechline Inverter Problem Help Needed please!!!
Discussion in 'Tech/Mech General' started by pinkie, Jan 20, 2014.
  1. pinkie
    pinkie Funster
    Apr 23, 2013
    376
    800
    Angus
    Guys,
    I have copied this from Freespirit's cheeky post (although can't deny it's true!!!) which he posted in the Morocco 2014 thread as it's a techie question and I suspect won't been seen, Thanks Pinkie!
    Pinkie - Inverter problem
    Hi all - I had a look at Pinkie's loss of 240v AC sockets today. She has a Vechline Power Convertisseur de Tension 1000w unit fitted which is tripped out with red and no visible reset button.
    Dieboy and myself have tried to find a user manual on the web but nothing other than a site wanting to charge 39euro for one.
    The unit has a USB port along side the control switch and alarm lamp which I suspect is for a computer reset ??
    If anyone has a similar unit or can find a manual Pinkie would be grateful for assistance.
    I have tried disconnecting the 12 v supply and reconnecting as in reboot with the output socket disconnected but that didn't work. The unit may well be duff - however the manual should when found shed further light ?? The input voltage is fine at 12.5v - trips at - 10.5v we did discover on line.
    Pinkie has asked me to post this on her behalf as her expertise is really more on Prada handbags - lol.
    Many thanks.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    as there is no visible reset button it may have an automatic thermal reset which would trigger if it was overloaded.
    Only two reasons to trip....under voltage or overload.
    If overload is the case the thermal reset may have gone mammaries up.
    There MAY be a fuse inside the casing...worth disconnecting from battery and taking the cover off for a butchers.
    DISCONNECT BATTERY FIRST.
  3. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    DISCONNECT BATTERY FIRST.[/B][/QUOTE]
    Spoilsport :Rofl1: still saved a name change from Pinkie to Brownie:Rofl1:
    • Like it Like it x 1
  4. pappajohn
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    Spoilsport :Rofl1: still saved a name change[HI] from Pinkie to Brownie[/HI]:Rofl1:[/QUOTE]
    or Smokie....or Flash. :Laughing:
  5. pappajohn
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    the 600watt version has an internal thermal fuse rated at 55degC.
    That the circuit board temp, not air temp.
  6. pinkie
    pinkie Funster
    Apr 23, 2013
    376
    800
    Angus
    Okay "funnyguys"...................
    What does it all mean to a blonde that knows more about prada handbags than inverters...........
    all the others are leaving me early tomorrow morning, can you give me a step by step guide for blondes that like prada handbags, I can get the cover off and see a fuse I should think, but any other tips here............we are desperate to charge phones/laptops!
    Thank you!
    Pinkie
  7. jhorsf
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    wet fingers stand with feet in bucket of water stick fingers 1 in live 2nd in neutral this will tell you if it is working:Rofl1:
  8. MikeD
    MikeD Funster
    Dec 21, 2011
    2,204
    1,922
    London
    Maybe made and sold under another makers name?
    A lot of companies just buy this sort of stuff in and stick their own label on it.
    Have you tried a search in Images?
    You might find another seller who includes a manual you can download.
    Or else post a picture of it and see if anybody recognises it.
    :thumb::thumb:
  9. Scout
    Scout Funster
    Apr 4, 2009
    3,410
    9,509
    doncaster
    I dont know inverters, but I do know safty, if you dont know what your doing with electric DONT do it.
    If as PJ says its got a themo switch off because it was hot (inside),
    it would have cooled overnight ( presuming you had not been drawing power through it)
    So if it dont work this morning, disconect from battery end , and buy a new one, you can see if its fixable back home.
  10. pinkie
    pinkie Funster
    Apr 23, 2013
    376
    800
    Angus
    Hi, That's helpful actually.
    Freespirit is an engineer so can look at most things but he's gone and thinks he can look it up at home and let me know, but of course you are right - I won't even bother worrying about this. We've been travelling without electric sockets all this time so may as well continue for another 3 weeks.
    I should add, the inverter has never worked whilst I have had the van, so it's not a case of me overloading the system.
    Thanks.
  11. veevee
    veevee Funster
    Jul 4, 2010
    984
    551
    Essex / central France
    Forget about the inverter and have it wired locally to bypass it with a basic mains trip setup.
    That way you will be able to use your 230v sockets safely without any problem when you are plugged in.
    There may already be a cut-out device fitted before the inverter, which would make by-passing the inverter simplicity itself.
    Get a local electrician to sort the by-passing out, it will be such a simple job.
    I think that without photos of the inverter and the incoming mains electricity set-up it's difficult for anyone to give advice at a distance.
    Good luck
  12. pinkie
    pinkie Funster
    Apr 23, 2013
    376
    800
    Angus
    Freespirit actually took a photo of it so as he arrives home tonight he may well read this and post the photo tomorrow.
    In the meantime, i'm not going to bother trying to sort out here, I shall just get it rewired when I get home as I want new lights etc as well. After the hassle with the respray, I'm not filled with confidence about Moroccan electricians!!! Bad enough in UK!
    Thanks! :thumb:
  13. pappajohn
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    now she tells us :Doh:
    Probably not even connected :RollEyes:
  14. pinkie
    pinkie Funster
    Apr 23, 2013
    376
    800
    Angus
    Thanks papajohn, but you are so wrongo!!!
    Its connected, but being blonde and can only do basic household electrics such as extending sockets and basic rewiring, car stuff too techie for me, my brain glazes over.....
    Come on freespirit, explain it again to these people!!!!
    Pinkie :Wink:
  15. MikeD
    MikeD Funster
    Dec 21, 2011
    2,204
    1,922
    London
    Techie stuff!!!
    Pinkie
    Everybody who is normal their brain glazes over :thumb::thumb::thumb::thumb:
  16. durhamahoy
    durhamahoy Read Only Funster
    Jun 11, 2012
    241
    114
    Durham
    What's an inverter?
    Webby
    :Eeek:
  17. pappajohn
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    in case this is a serious question.....
    An inverter is an electronic gadget which converts 12v dc battery power into 230v ac mains power enabling you to use mains powered appliances while not on hookup.
  18. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,193
    Rutland
    It's what you use to charge laptops and phones !
    Unless your using 12 v leads :Wink:
    Vlad
  19. pappajohn
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    sorry, it was meant tongue in cheek...maybe needed more smilies :RollEyes:
  20. Freespirit1
    Freespirit1 Read Only Funster
    Sep 3, 2013
    182
    252
    West Wales
    Pinkie - Inverter problem.
    Guys - please carefully read what I have stated in Pinkie's first post here - and yes I will post the photo of the inverter tomorrow and will try and find the manual on line.
