vec weight upgrade (2 Viewers)
Family Guy
266
202
runcorn
a class
since 2001
thinking off changing to tag axel motorhome at present plated for 4500k want 5000 at least
alko running gear :Doh:
43,319
49,387
depends if there is a 5000kg version available.
your will already have been uprated to 4500kg so may not be possible.
give SVtech a call, they know what they are doing and will be able to confirm one way or the other.
Link Removed
Family Guy
Family Guy
266
202
runcorn
a class
since 2001
no ive sold my van looking at another one at moment but its only 4500 last van was 5000 and was allways up on it :Blush:
JockandRita
11,462
150,048
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
I don't know what year you are looking at Eddie, however, after a front suspension upgrade, I uprated our Tag Hymer from 4500kgs to 5000kgs through VOSA. SVTech didn't want to know, unless I gave them £300 plus, to do it as a paper exercise on the rear axles. :Angry:
Cheers,
Jock.
haganap
12,758
26,438
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Might be cheaper for a gastric band mate :thumb:
Lol, Eddie, try ringing SVTech, Based in Preston, they will advise you on what can be done or needs doing and what can be done
Family Guy
Family Guy
266
202
runcorn
a class
since 2001
Cheers,
Jock.
what was involved in that jock sv tec weren't helpfull:Doh:
Family Guy
Family Guy
266
202
runcorn
a class
since 2001
believe me its not:Blush:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
You really need to know the weight distribution.
I have 2100 front 2400 rear but 4250 gross. Last owner weighed it loaded at 1910 front and 1880 rear so stacks of spare at the back. Some vans are very badly balanced and are overloaded even on the front in some cases
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
best euro van for over 5000kg is one of these..
plated at 6000kg with a train weight of 9500kg if your licence will allow you over 8250kg
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if you are looking at uprating a tag if the rear axles are 1500kg each then should be a paper exercise alko changed the spec on the chassis when fiat changed to the x-250 and uprated them to 5000kg if it is older than 2006/7 then you may have problems as the older ducato wasn't as capable so were capped at 4500kg.
Family Guy
Family Guy
266
202
runcorn
a class
since 2001
Had the burstner version of that want a class now
Family Guy
Family Guy
266
202
runcorn
a class
since 2001
Its a 2003 tag alko set up so might struggle seen 2005 advertised as a 5tonner have to sit down and think about it :whatthe:
JockandRita
11,462
150,048
Lincs/Cambs border
N+B Flair 8000i
Eddie,
Ours is a 99 Fiat/Alko chassis which needed a suspension upgrade due to the wallowy feel every time we went into a bend or a roundabout. The cost of rear air suspension was prohibitive, so we looked at a front suspension upgrade from www.goldschmitt.de.
Please see a previous reply about the subject >>Here<<
HTH,
Jock.
Family Guy
Family Guy
266
202
runcorn
a class
since 2001
thanks jock if I decide to get the van I will bend your ear to help me sort it out I remember s v tec last time I had a van like this they didn't want to know so was always over ,the van I spotted on 5 ton chassis had rear air suspension don't know about the front
my swift was always front end heavy due to pod I think (hope) whilst in Germany looked at getting air on the front once they told me the cost I moved my batteries to just in front of back axel levelled van nicely better ride etc:thumb:
JockandRita
11,462
150,048
Lincs/Cambs border
N+B Flair 8000i
Eddie,
Our MH is plated at 1500kgs on each rear axle, but both axles have a tiny oval plate on them rating them at 1750kgs each. This is where SVTech get their extra 500kgs uprate from, ie, 2 x 250kgs, and it's nothing more than a low cost paper exercise for them, but an expensive one for the customer. :Angry:
I can't comment on a more modern Alko Tag Axle Chassis, but I do know that where rear Air Suspension is fitted, it often facilitates an uprate in GVW, which would not normally have been possible on some vehicles. When SVTech supply and fit the suspension kit, they also do the uprating and plating as part of the same package, if required.
My stroke of luck was that I had paid extra for the Goldschmitt engineer's report which listed part numbers as well as the EU Type Approval Reference, otherwise VOSA wouldn't have wanted to help. VOSA (both local and national) were brilliant BTW, and couldn't have been more accommodating. ::bigsmile:
Good luck with it Eddie. :thumb:
Cheers,
Jock.
