Van level (1 Viewer)
paul18
171
34
Somerset
C class
newbie, but was caravanner for 20 years
On our 2nd site now and I have noticed when on level ground the front end is lower than the rear meaning I have to use the yellow wedges to get it horizontal. Is this normal with some vans? Ours is Ace modena. Sorry for another thread, getting used to our new baby!
scotjimland
2,256
9,780
A Woosh bang
I've noticed it on several vans.. I imagine if it were fully laden it may level out .. ?
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Certainly happens on our AutoTrail and I'm sure our previous Swift was the same.
Most of the time I don't worry about it being a tad down on the front and we are now quite used to it.
If it was down at the rear however it would be a problem sleeping.
Richard.
160
196
Cambridge
Dethleffs A 7870-2
Newbie, caravanner since 2008
Here's a stupid question - why don't MHs come with corner steadies as standard, like caravans? I suppose they're too heavy?
Worrying my name'll be mud on first outing, if the campsites aren't totally level. Planning on getting air suspension but need the smoke to clear a little on the credit card. :)
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Sounds like your van is on a Ducato chassis, most are these days, and the nose down attitude is normal. A slight slope on the pitch will level the van, otherwise, use levelling blocks. I believe the nose down attitude gives these vans good stability at speed.
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Corner steadies won't level a motor home..........neither will air suspension so keep the cc in your pocket and save yourself some money. :active:
paul18
paul18
171
34
Somerset
C class
Yes, Fiat Ducato chassis
scotjimland
2,256
9,780
A Woosh bang
correct..
you can have them fitted to 'steady' the van.... some vans do move about a lot when your walking about.. but will not level it..
if you want to level the van without leveling ramps you can fit hydraulic jacks .. one at each corner.. many RVs have them,...arrive on site, press button.. down they go and .. presto.. you are level..
downside.. expensive, and use of payload
D
Deleted member 29692
Ours is the same. It seems to be a bit of an optical illusion as it always looks far worse outside than it actually is on the inside.
D
We have rear steadies on ours. As @ScotJimland says they aren't for levelling it, just to keep it from moving around too much.
IMO they are a complete waste of time and I never use them (y)
160
196
Cambridge
Dethleffs A 7870-2
That's probably why we didn't get them as an option NickNic.
Getting my gadgets mixed up! :rolleyes: Jeroen knows it's hydraulics - as if he'd trust me to choose the toys. :ROFLMAO:
Puddleduck
12,378
43,951
Scottish Borders
Without at present
On and off for many years.
Ours is slightly nose down as well. We use the leveling blocks if we have to, doesn't bother us much now as it seems to be "normal" on Ducato based vehicles.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
No, you were right. There is air suspension and there is air-assisted suspension. Full air suspension is expensive - £1.5K+ but they can be used to level the vehicle, just like you can with corner steadies on a caravan. Air-assisted suspension costs a few hundred pounds and is reported to give a smoother ride than the standard setup as they replace some solid rubber "bump-stops" with air bags. You can self-level with air-assisted if you have an on-board compressor, but the cheaper installations are just inflated using a garage tyre pump. My understanding is that the amount of travel you can get from air-assisted suspension is limited compared to full air suspension but I would not claim to be an ex-spurt.
It has been discussed here before and some folk have published handy guides on how they fitted air-assisted suspension. (Edit: See above!) What you can or cannot do on each MH depends very much on the base vehicle.
Air suspension: http://www.vbairsuspension.co.uk/en/page/applications/motorhome.html
Air-assisted suspension: http://www.rhinoinstalls.co.uk/airride.htm
Other suppliers are available - those are just what Google came up with. :) Ask on here for recommendations if you want to investigate further.
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
I don't think it is a fault. The front I believe is the correct ride hight and it is the rear which is too high! If you look at a modern car they often have air dams underneath the front bumper. This is to reduce drag and therefore improve mpg. The idea is to avoid a great gap underneath the front of the vehicle. Of course it could be argued on a MH you probably wouldn't notice the difference but if the front of your vehicle isn't hitting things then I would leave it alone. I actually like the slight difference because on a gently sloping site I can pitch in front or rear first as appropriate so the vehicle levels without the need for ramps.
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
In ours the difference looks worse from the outside than it is in reality. On a flat pitch it would be level enough for us. Wine stay on the table, sink drains away. We do have the benefit in ours we can sleep either way round, so to speak.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Wifey won't have her head at the front of the pitch anymore when in bed! So it's reverse in every time now. So I prefer a slight slope to the back
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
It is normal for some vans to sit off level. Personally I always use ramps to level up as being even slightly off level is a pet hate. If off level, doors dont close properly and worse still the fridge does not work correctly. How many times have I heard people say "My fridge does not keep things as cool as it used to" only to look at the van and its sitting as though its had a double blowout. Over time being off level destroys the fridge. I know, have had to replace enough in second hand vans.
656
2,440
NOTTINGHAM
Autotrail Savannah
Almost a Newbie but not quite now.
We have air assist suspension and find the ride ok, also have rear steadies but with the overhang on our MH it is needed as the wobble is significant when not used. She does seem to sit level though.
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Our air suspension will level our MoHo, no problems on most sites.(y) Ok, 20% hill may be a little difficult.
Regards,
Trikeman.;)
Langtoftlad
8,860
150,375
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
Well, I can now contribute from my vast experience of renting one for a week... :rofl:!
The Mooveo P6 definitely looked tail high from the outside yet according to the phone's bubble level app - the table, the cooker top etc were almost perfectly level!
So whether it's an optical illusion, or the interior is built with an exactly offset slope the other way (can you imagine the standard of craftmanship required to do that!) I cannot say...
But in my "excitement" of playing with a van for the first time, level didn't enter my head. Reverse parking, straight, without hitting bollards was my first priority :whistle2:.
But when I went to bed... :wine:... I can't say I noticed any leanings one way or another - I have to assume I was lucky with having several absolutely level pitches (y).
Reactions: DBK
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
If you wake up on the floor dribbling from the right, you have -
a) not levelled correctly.
b) had a bloody good night out.
Both are fun, but can leave one feeling a little queezy though.
Trikeman.(y)
funflair
19,305
30,071
Guisborough
MORELO palace
since 2012
Four channel 4C air suspension will level the van on a reasonable slope, but yes it will hammer the CC.
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Never bother with levelling up!
When off site wilding in a field or on the beach just park as level as I can.Normally just read the ground and when in position look over my shoulder down the van to gauge how level we are ,it's not that hard.
When on site we find most pitches are reasonably level if there's a slight slope we will reverse on or drive on to suit ,as long as my head is slightly higher than my feet I sleep ok.
I've spent a good few hours pissing myself watching people revving the nuts off their van guided by co pilot up and down on blocks front to back and side to side on a pitch that's basically level!
Vlad
