Van Bitz Battery Master alternative (1 Viewer)
Oct 14, 2007
3,993
6,252
Rochester
Auto-Trail Mohawk
16 fun filled years
Hi,
Someone posted on here an alternative to the Van Bitz battery master, can anyone remember what it was called? I have searched but can't find the thread, I believe they said you could get thme on flebay.
lunarman
2,156
2,451
South Glos
since 1994
CAK Tanks do something similar there stock code is BCM12
Download their catalogue and price list here Link Removed
Lunarman
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
If its the gizmo that diverts power from the solar panel when the leisure battery is full to the engine battery. Its the CBE CSB-2 and available from ebay. It works great as I fitted one to my FFB. I do have a spare in the "Stores" if you cant find one on ebay.
Jim
Ringleader
Jul 19, 2007
36,417
130,895
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Hi,
I have a new/unopened vanbitz battery master for sale, £45:thumb:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
Lunarman
i have the bcm12,and can confirm it does the job:thumb:
Diabalo
Oct 14, 2007
3,993
6,252
Rochester
Auto-Trail Mohawk
16 fun filled years
I have a Van Bitz battery master fitted Jim and to be honest I'm not sure it does the job, the Vehicle batt keeps going down and but the Hab batt is fine, if I turn the hazards on I can see the battery master light flashing on and off which indicates it's putting a charge in. I believe It's supposed to put a charge accroos once the Vehicle battery is .5 of a volt below the hab battery but that doesn't seem to be the case. maybe it's knackered.
paulmold
892
302
North Wales
7 year (25yrs a tugger)
Hi,
Is this the one you mean..
Link Removed
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
im sure Eddie Vanbitz would be able to advise on this.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Broken Link Removed
Scroll down about 5 pages to catalog page 81 and its on the bottom right:thumb:
Geo
Link Removed under its old part No CSB2 , Me thinks
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
much cheaper than CAK
but do not buy this if you dont have solars! buy the vanbitz battery master
Link Removed
sedge
Jul 7, 2009
5,504
13,115
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
I should delay till next week then email Eddie a link to this thread, then he can get a chance to comment - he's at the NEC at the mo (has a stand anyway so I assume he is!) so may not see this otherwise.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
We already know what Eddie thinks, want a reliable one get the Battery master want to save a few quid get the cak tank or other foreign made jobby
he has nothing bad to say about competitors versions, only states the obvious, to me anyhow you gets what you pay for simples
Techno
Jul 28, 2010
15,475
20,756
May 2010
It has nothing to do with price and everything to do with purpose.
Eddies device was designed to maintain the engine battery at all costs were no hook up or solar was available to delay the flattening of the battery due to strike back alarms
The CBE unit delivers a higher charge transfer rate only after the leisure batteries are full and is designed for installations where solar supports the batteries.
CBE are a very big Italian electrical company providing for many thousands of motorhomes
AND where do you suppose the battery master is manufactured
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
or over wintering on ehu:thumb:
Techno
Jul 28, 2010
15,475
20,756
May 2010
My own CBE unit top left. As soon as my leisures reach 13.6 volts it send up to 4amps to the engine battery
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
There made in the Uk
I was quoting Eddie not second guessing him:RollEyes:
Techno
Jul 28, 2010
15,475
20,756
May 2010
possibly why its so expensive :roflmto:
But again its not about the price.
If a van is parked long enough without solar or hook up the battery master will flatten the leisure battery in its effort to maintain the engine battery.
that isnt a fault it is designed to do that
A CBE unit only gives charge to the engine battery when the leisure is full and stops giving charge when the leisure drops to 12.6 volts
Diabalo
Oct 14, 2007
3,993
6,252
Rochester
Auto-Trail Mohawk
16 fun filled years
I have tested the parasitic drain and it's 140 ma without the alarm and 160 ma with the alarm on.
Now if my maths are correct that's a 3.84 amp drain over 24 hours and 26.88 amp drain over a week which is 25% of my 100 amp hour battery:cry:
Still not sure if my Vanbitz battery master is doing what it should do.
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
:RollEyes:Or the engine battery is knackered! Perhaps not, but why does it keep going down? :winky:
Eddie
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
That quiescent drain is too high and needs resolving. Do you have a navigation system? Most problems are caused by changing feeds to radios so that the ignition is by passed, but in effect leaving the radio on "stand by" all the time. An addition ON/OFF switch should be inserted in series on the "ignition" circuit.
Eddie
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
Hi,
The cheapest alternative is a piece of wire between the engine and leisure battery (s) with a switch in it! :winky:
If your is faulty send it back simples! But I think that you have other problems.
Eddie
Diabalo
Oct 14, 2007
3,993
6,252
Rochester
Auto-Trail Mohawk
16 fun filled years
Eddie
Eddie the radio has been by passed, I will disconect it and see what the battery drain is then, thanks:thumb:
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
Regarding price, I only retail the damn things due to demand. It was originally designed to be installed by us (Van Bitz) simultaneously with Strikeback @ £69.95 installed.
However:-
The unit is hand made in relatively small batches, for us by a bespoke small run manufacturer.
It is waterproof, so can be mounted under the bonnet or in battery locker.
It is made in the UK.
It has re-settable internal fuses, so when connected to a fused circuit no additional fuses are necessary.
We offer a lifetime warranty on it.
It is fully "potted" so vibration proof
If you connect it up the wrong way round it will simply switch off.
We have units that have been working for over 15 years now. Frankly I make no apology for the price as we don't really mind if we retail them or not as we install the majority of them, for the benefit of our customers who want to leave the motorhome for longer periods without the fear of flat batteries.
different spec's normally result in different prices, as with most things in life:winky:
Eddie :thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Snap-On said:
We'd rather explain the price of quality than have to apologise for something less ...
