valve
Discussion in 'Tech/Mech General' started by mariner41, May 7, 2010.
  1. mariner41
    mariner41 Read Only Funster
    Aug 4, 2009
    23
    scotland
    Hi All
    Can anyone help me with the positioning of the draining valve under the
    wardrope in my autoquest 120
    I drained the water off for the winter but cant remember the positioning before
    I fill the tank.
    I tried the manual that came with it but I'am none the wiser.
    Maybe there is a web site with pictures:Eek!:
    Hope you can help.
    All the best
    Jim.
  2. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Start filling, if water falls out it's the wrong way:thumb:
    :Blush:I had this with our RV last winter, I was merrily filling and started thinking, mmm this is taking it's time, then was hit by the I can hear running water moment, and sure enough I'd got in a muddle and left one of the drain taps open:Doh:
  3. Phil
    Phil Read Only Funster
    Oct 21, 2007
    226
    Herts
    If the handle is in line with the pipe it is open. If the handle points across the pipe it is closed.
    Phil.
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,940
    If it is like our Autoquest 100 then it needs to be horizontal to be closed. Vertical is open and will let the water drain out.
    As Dodgey says, if water falls out it's the wrong way - or a bit off the horizontal.
    Graham
  5. davejen
    davejen Funster
    Aug 21, 2008
    1,260
    715
    Kirkpatrick Fleming Dumfries
    Thought you'd have been in a PUDDLE, not a MUDDLE!!!!!
    Dave:Rofl1::Rofl1::Rofl1:
  6. pendy
    pendy Read Only Funster
    Oct 9, 2008
    155
    97
    Birmingham
    GJH is right if it is in the straight up posion (vertical) the water will run straight out it needs to be in the horizontal.HTH
  7. mariner41
    Aug 4, 2009
    23
    scotland
    Thanks forall for the advice.
    It works if you bring the switch towards you but
    not all the way down or it runs out when you try to pump hot water:thumb:
    once again thanks.
    Jim
