Using shower in MH!
Discussion in 'Motorhome Chat' started by gypsyrose, Dec 16, 2011.
  1. gypsyrose
    gypsyrose Funster
    Jun 22, 2008
    240
    33
    Mid Glamorgan
    Embarrassed to say that we have been motorhomers for nearly 30 years but I am still asking this question?!! Would not dare ask the "other side" lol. Question is "when you use shower and mabe both of you shower one after the other, you are going to use a fair bit of water, right?? :Doh:
    Ok, ok, lets get to the point...!! Over all the years, we have rarely used our shower....ok, AFTER we shower (and obviously use water!) ..now for the question...if you then want to use gas heating in MH is it a problem....what if van runs out of water?? :Eek!:
    We ared about to set off in a "new" mh and will want to use shower and also gas heating??
    Thank you in advance, you lovely FUN people!! :Rofl1:
  2. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I think we might need to see some photos to fully understand this one
    barry:Smile:
    • Like it Like it x 2
  3. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    You hit the nail right on the head.
    Unless you have a city water supply (or equivalent) and a waste disposal point on hand it cant be done.
    Jim
    :Smile:
  4. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    Are you asking if the heating and water are on and the water runs out will it damage the heater?
  5. hilldweller
    Dec 5, 2008
    27,709
    26,809
    Macclesfield
    No problem with our Truma.
    • Like it Like it x 1
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,062
    3,467
    Eastbourne East Sussex
    The answer is probably not to run out of water. I use the van shower frequently and as long as the tank is full there is no problem with two showers as long as you bear in mind that you are not at home with limitless hot/cold water.
    The Truma water heater holds around 10L and will reheat in 20mins (on gas, much slower on mains) so assuming half hot and cold you can have two showers as long as neither uses more than 10L (20 if you wait for the water to reheat)
    I have no problem showering in 10L of water but the method is
    1. Get wet, turn off water
    2. Soap up,scrub whatever.
    3. Rinse off, turn off water.
    With practice no problem but don't think you can run the shower continously as you will rapidly run out of water. :thumb:
    • Like it Like it x 3
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,874
    23,573
    Narrfoook
    I dunno.. you just cannot get the staff nowadays..
    To answer your question
    The water heater, whilst often in the same unit, is separate from the warm air heater
    if you run out of water the warm air heater will still work fine and without damage.
  8. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    I dont understand your question; are you thinking that it takes that much gas to heat the water there lill be non left to heat the van?
    As to the amount of water a shower uses, we use about 5 ltr for 2 showers.
    Doug...
  9. Teasy2007
    Teasy2007 Funster
    Sep 26, 2007
    1,675
    743
    Rotherham South Yorkshire
    We have a variation of this, we have a small bowl with hot water which we use to soap up and wash. We only use the shower to rinse. We always have 2 showers a night and this works very well indeed. We have never run out of water.
    Ginny and Mike
  10. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    I would think, if there were a problem, that you should run out of water whilst showering with the heating on...the truma would shut down/off....My belief there will be some safety valve/ shut off device built in.......
    I think they run as two separate items ..so not a problem..but I stand being corrected..
    Mel:thumb:
  11. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    It seem YES... as I have said...if you run out water you can still run your heater...If I have understood your question correctly
    I hope this helps click the link below
    Mel
    http://www.truma.com/uk/en/heating/tips-faq.php
    Combi-Modelle
    Combi models: Is it possible to completely close a warm air outlet or warm air line in the case of the Combi (E)?
    How long does it take for water to heat up in the Combi?
    In summer, is it possible to just heat up water without heating up the living area too?
    Is it possible to use the Combi heating function without water?
    Of course. The Combi water tank can be heated up even without water.
    Why does the D.C. motor continue to run after the heater has been switched off?
    Does my Combi water tank need to be descaled or sterilised?
    Is a Combi D 6 E also available?
    Is it possible to retrofit both heating elements in a standard version of the Combi 4/6?
    Trumatic C
  12. EthnGeoff
    EthnGeoff Funster
    Jan 13, 2010
    302
    230
    County Durham
    If you have been waiting nearly 30 yrs then you probably ought to use the shower, but the heating should still work if you run out of water, just make sure you have it set to heating only and not heating + hot water.(otherwise the safety cut out would operate)
    Geoff.
  13. gypsyrose
    gypsyrose Funster
    Jun 22, 2008
    240
    33
    Mid Glamorgan
    Sorry t was hard to understand what I meant...when I started the post all was peaceful here then chaos reigned, lol!! Peopel in and out, phone ringing etc!! :Wink:
    However, many of you managed to get the drift and I thank you for that!!
    I am just afraid of something dreadful happening if water should run out and we wild park a lot so cannot keep tank full all the time.
    Very helpful tips, thank you!! :BigGrin::thumb:
  14. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,315
    731
    Darlington
    Your water is delivered to the heater by your water pump. If you run that dry you could damage it. However if you turn off the tap as soon as you notice the water supply running out you should have no problems.
    The hot water is pushed out of the boiler by the cold water being pumped in so the boiler will not empty. That is why there is a separate drain to avoid frost damage to the boiler.
    John
  15. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    we wild camp alot you can get water from most Macdonalds they have an outside tap all ways ask the manager and not been turned down yet :thumb:
  16. motorhomelover
    Jul 28, 2010
    1,719
    613
    The world
    hope your drift is not too bad after 30years of no showers :Rofl1::Rofl1::Rofl1::Rofl1:
  17. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    This is what I like about this Forum. I maintain there is no such thing as a stupid question, only stupid answers. It is good that the OP was confident enough to ask the question without fear of ridicule (and I don't call the gentle leg pulling ridicule) and I guarantee there will be others who did not have the confidence to ask the question but who wanted to know the answer.
    Steve
  18. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,087
    4,617
    Zummerzet
    As already said heating and water are two separate systems - there are safety systems in place and the most important one is that when you 'run' out of water the hot water tank is still full - as John stated the water is pushed through by the pump so if the pump cannot push water the tank remains full.
    Showering in the van - never do anything else - 40 litre aquaroll does 2 showers - cups of tea and washing up for 24 hours minimum. Our routine is fill the basin wash all over quick wet down of head shampoo hair shower on rinse off no problem at a guess I would say our daily consumption of water is around the 30 litres average :thumb:
