Using Levellers on Your Own (1 Viewer)
JackieP
666
1,400
Isle of Man
Since 2006
So, yes, one of those things that come to you at 3am when you're toddling off for a wee, trying not to think about anything that might wake you up and suddenly wonder…
how am I going to use the chocks on my own?
So, can it be done and any hints?
trekkin
332
490
Staffordshire
Rv
5 years but still learning
Could try parking the van then placing a object, or pointer in line of site ( maybe a pole that lines up with the bottom of the windscreen. Then look where the levellers are required, place then by the side of the wheels at the appropriate place, reverse back move the levellers in and drive forward to your mark onto the levellers
Takes a it of practice but achievable.
D
Deleted member 29692
Just position them. Drive onto them then get out and have a look. I usually check for myself anyway even when 'er indoors is outside signalling that we're level.
Cal54
3,805
62,010
Southport, UK
Leisuredrive Renoir
Since 1996
It is something I often do. Line everything up and then I open the drivers door and take a visual marker (or use something as mentioned in trekkin's post) and drive onto blocks - Simples!!
A bit of practice and you will have it mastered. Just a word of caution though, don't over do it, damage can be done to the underside if you go off the top of the ramps.
Apr 29, 2009
1,204
741
West Sussex
Burstner Nexxo T740
since 2008
If I were on my own I would try to park so I can use the leveller on the front drivers side (so either raising the front or drivers side of the Motorhome). Then I would reverse onto the levellers with the drivers door open so I can see I am not going to drive off the top. I would have to find somewhere in the front to put the spirit level so I can see it though as we currently use the rear table.
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
You'll get a feel for how far up the leveller you are from the engine revs. Just don't go blindly too far:(
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
It's not an exact science really.. we prefer being slightly nose down (means the sink and shower drain easier.
We
Find flatest point to park .. check with level (or glass of water) or using just eye.
Decide best position for ramps if req
Reverse or drive slowly onto them.
Re check
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
An easy way..
Get someone to assist ( as in watch the bubble ! ) to get it level the first time.
Use some playdough or similar to attach the bubble on the dash somewhere it can be seen from the drivers seat and afix. ( by using playdough you can attach it in a level position by having said dough thicker on one end or what ever .. the point of attachment does not have to be flat )
I never rely on anyone when driving up them anyway.. it is just the 'is it level yet' side of things ..
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Drive onto them then get out and have a look. Simples.
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
I always open door and lean out to see where wheels are as I saw brand new van overshoot the big milenco 4 level ramps ouch I couldn't bear to look at the damage that must have been done .
J
JackieP
666
1,400
Isle of Man
Since 2006
Excellent stuff - thank youse!
Love the idea of the play dough to get the bubble machine to sit level and also using an external point for reference.
I've never overshot the top level, somehow I think I'd get a feel for it if I did and I'm not anal about having it perfectly level, only level enough for the water to drain and the fridge to light.
Thanks all!
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
If you use Milenco quatro or Triple levels you can feel the wheels going into each position. We have small cross level stuck on kitchen work surface.
Reactions: DBK
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
That's pretty good advice but just look at Mr Colpot's Avatar, he thought that was level!.......:imoutahere: :wink:
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I've always done it on my own. Much easier than trying to interpret the advice given by 'helpers'! :D
Feb 24, 2013
13,083
101,446
Bolsover, Derbyshire
Hymer S800
not long enough
I am guessing your main fear is driving right over the top? We have Millenco Quattro and by the time you are at the top of them you feel so high you will definitely have stopped !! In fact I have got out convinced I must be perched on the very top due to how high it feels and only been on the third level. As previously said they have quite pronounced dips at each of the set levels
Just take it steady, put ramps against the wheels don't take a run up, make sure they are straight, get out and check part way, you will soon sort your own best way I am totally confident (y)
Jan 11, 2010
2,747
9,572
Chester
Auto-trail
Well that`s our 13th year & still loving it.
Check your level with spirit level on kitchen worktop to decide which wheels require levelling.
We have one of those small triangular levels which shows both axis.
If your lucky the wheels that require raising will be the front ones so you can just watch from the drivers door how far you need to reverse, if not place the ramps behind the wheels, (I always reverse up the ramps) with your drivers door open mark out on the ground behind the front wheel the full length of the ramp with a stone or anything else you can find, this will ensure you don`t driver over the top of the ramp.
A little practice will gain you the knowledge you have to reverse up the ramps to gain the level you require.
Lenny HB
53,421
149,948
On the coast in West Sussex
Hymer B678 DL
Done it a few times just go carefully, I don't recommend reversing onto ramps, with the high reverse ratio modern vans have it's puts a hell of a loading on the clutch.
I don't bother with a level, if it feels level it is level.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Thanks all!
I don't because there are times it's not level on the top step !
I like Tech. A reversing camera mounted on a sucker. Stick to suitable place and watch the screen. You wouldn't half impress the onlookers.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Well, I'm making this up as I go along....
Broken Link Removed
Just fit a 12V cigarette plug on this, don't "install it" as such, prop the camera on the ground holding the TV, move to cab holding TV, go back and re-position coz you pulled the camera, get in cab and go up the ramp safely.
Looks like the camera could be used with a tent peg.
Then unplug and stuff it all in a shoebox.
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
If you can't see with the door open, maybe a mirror of some kind placed in the right position on the floor might be a option.
MikeandCarolyn
2,170
1,468
Since 2009
Fun comes when you need to level in two directions-one ramp tight against wheel and one placed a certain distance in front of other wheel (this distance calculated by experience ) so that you end up on ,say,top of one and 2/3 up other one.
The feeling of satisfaction to see bubble dead centre of a cross level is huge (y)(y)
StefAndDi
408
931
Near St. Austell, Cornwall
Ceased motorhoming 1/3/16
2010 to 2016
I often arrive on site ahead of Di and when I had a Fiat Ducato-based MH that was my preferred method and it worked very well for me.
However, my current vehicle is Mercedes-based and the wheels are set in much more and cannot be seen when you are in the vehicle, even if you hang out of the drivers door window.
So now I just ask for assistance from the site warden or any friendly-looking camper.
I always show my appreciation by not tipping my grey waste onto their pitch.
Stef.
